Old 01-22-2008, 10:56 PM
fifty5chevy fifty5chevy is offline
1500 Truck ignition key cylinder Remove and Replace
C/K 1500 Truck ignition key cylinder Remove and Replace proceedure needed, it has tilt steering wheel. the key sticks in the ON position.>thanks for the reply !
Old 01-22-2008, 10:57 PM
Re: 1500 Truck ignition key cylinder Remove and Replace
I forgot to add --- its a 1993 Model Year.
Old 01-23-2008, 09:13 AM
jayman4pu jayman4pu is offline
I'm getting ready to do this same thing. I don't have my Hayne's manual here at work with me, but the procedure (along with their typically crappy pictures) is in there. I know you have to remove the steering wheel, but I don't think the tilt becomes a problem so long as you leave it alone after you've got it taken apart.
Old 01-23-2008, 03:44 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Tilt wheel does not affect the lock cylinder removal
http://www.automotiveforums.com/vbulletin/t714776.html
To answer his question, which I don't remember seeing at the time, there is no easier way, and the key position doesn't matter. If it is out of the "lock" position, you can use the key to pull the cylinder out.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-23-2008, 03:53 PM
j cAT j cAT is offline
before you do this i have found worn keys will give this type of problem.......
Old 01-23-2008, 04:14 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Is this a common issue with these trucks? I have a 1994 C1500 (non tilt wheel) and had the same problem back in 1996. Luckily it was replaced under warranty.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 02-04-2008, 06:09 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
common problem
replace it
new ones are cheap
have to remove steering wheel, lock plate, and pull the turn signal assembly up far enough to get to the screw or tang that retains the lock in the housing
most have a screw
some dont
torx bit
wheel/pulley puller and two bolts,
lockplate compressor tool
both tools 15 bucks autozone etc
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
