Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 01-30-2008, 08:20 AM   #1
cruiser69
Upper Intake Manifold
I have a 2002 GT 3.8 with 61K on the engine. I had the upper and lower intake gaskets replaced about 10,000 miles ago. Now I am told that the upper is leaking again already. Could this be because they never replaced the actual intake and just the gaskets.
cruiser69 is offline   Reply With Quote
Old 01-30-2008, 10:42 AM   #2
richtazz
stupidity should hurt
richtazz's Avatar
Re: Upper Intake Manifold
Yes, it is not as common on the 00-up's for the UIM to fail (it's usually just the gasket) but if let go too long, the coolant leak can erode the passages in the UIM. I personally wouldn't take the risk on reusing the OEM plenum with the aftermarket replacements being so cheap these days.
Old 01-30-2008, 11:12 AM   #3
cruiser69
Is replacing the plenum and gasket a hard job. I would like to repair it myself instead if paying someone to do it again.
Old 01-31-2008, 07:57 AM   #4
GTP Dad
Pontiac Guy
It is not hard to replace the gaskets for the UIM but it does take time. Check the maintenance section as there should be something there to instruct you on the proper procedure. However, I would still invest in a manual to make absolutely certain that you are doing the job correctly. Good Luck!
GTP Dad is offline   Reply With Quote
