Old 12-03-2007, 10:04 PM
rtc1139 rtc1139 is offline
1988 Chevy k1500 missing/sluggish
Hi. I need some advice. I have a 1988 Chevy K1500 with a 350 and TBI. My truck starts great and idols like a dream. When I try to drive it or get higher RPM the truck tends to miss and backfire if you floor it when it starts to miss. The engine never dies. This causes the truck to shutter. I have tried the following: new plugs, wires, ECM, cap, rotor, oxygen sensor, knock sensor, battery, fuel pump, fuel filter, and ignition module.
Please help as I am running out of money and time....
Thank you in advance.
Old 12-04-2007, 03:28 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 1988 Chevy k1500 missing/sluggish
Check the exhaust backpressure. Sounds like possibly a plugged cat.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-21-2008, 08:18 PM
ridebetr ridebetr is offline
Did you fix the problem? I'm having the same problem.
Old 01-21-2008, 08:24 PM
G.A.S. G.A.S. is offline
I would like to know the cure as well
Old 01-22-2008, 12:13 PM
j cAT j cAT is offline
take out the o2 sensor and run it with the o2 hole open if it runs better the cats or exhaust are plugged.....
