Old 01-14-2008, 06:41 PM   #1
Scott G.
overheating 96 3.1 Lumina
I have a 96 3.1 Lumina.It is overheating and does not have any heat inside the car.The upper rad. hose is hot but the lower hose is cold.Also the heater hoses are cold.I would think if it was the thermostat I would still have heat inside the car.Fluid levels are full in both the rad. and the overflow jug.I suspect the water pump but have never seen a bad impeller or broken shaft.Would appreciate any help.
Scott G. is offline   Reply With Quote
Old 01-14-2008, 06:54 PM   #2
j cAT
Re: overheating 96 3.1 Lumina
this is usually insufficient coolant are you sure you are good to -40deg f. wisconsin is next to alaska for cold weather. also it is possible you have too much coolant this will cause the same type symptoms you have...............i know a guy in milwaukee who had a leak and just kept adding coolant at -5deg f engine overheated................it also could be the belt is not turning the water pump ha ha...
Old 01-14-2008, 07:47 PM   #3
Tinman238
How many miles on the car?
Tinman238 is offline   Reply With Quote
Old 01-14-2008, 07:52 PM   #4
Scott G.
220,000 miles
Old 01-14-2008, 08:21 PM   #5
Tinman238
The problem could be a clogged radiator, since the upper hose gets hot, but not the lower. Can you see scale and buid-up in the radiator when you remove the cap? (when the engine is cold, of course) If the car hasn't had the cooling system flushed once in a while, that may be the problem. If its not the radiator, and you're sure the thermostat is good, my guess would be the water pump. Make sure the lower hose hasn't collapsed, also.
Old 01-15-2008, 03:38 PM   #6
j cAT
because he has no heat coming out the heater, thermostat isn't causing overheating. it is possible besides what i already stated that the water pump impeller is bad or as you suggested coolant system sludged. mixing of dex cool and silicate coolant will do this .........
Old 01-29-2008, 11:53 AM   #7
nascartony05
nascartony05's Avatar
Thermostat could be stuck open, or it could be a wore out water pump.
nascartony05 is offline   Reply With Quote
