Go Back   Automotive Forums .com Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 01-09-2008, 10:42 AM   #1
superdesi
Are new wheel bearings necessary when installing new axles?
I finally have a set of new axles ready to install on my '93 E since I'm really annoyed of the clicking I get on right turns. However, now my mechanic tells me that it would be better if I install new bearings as well. He says its kinda like installing a new water pump when doing timing belts on cars............highly recommended.
My bearings don't squeal at this point (70K) and only my left axle is bad but I said what the heck and decided to order both axles. Should I also get new bearings?
- 1993 Sentra E Coupe
- 2005 Chevrolet Malibu
- 1999 Chevrolet Suburban
- 2003 Town Car Signature
superdesi is offline   Reply With Quote
Old 01-09-2008, 02:10 PM   #2
slideways...
slideways...'s Avatar
Re: Are new wheel bearings necessary when installing new axles?
not totally necessary but if its never been done you might consider it. not exactly like wp while doing a timing belt because the water pump replacement adds usually very little labor cost to a timing belt job. with wheel bearings you do have to tear into the hub a bit farther than just doing an axle, i would say ask your mechanic what the labor if you did it with the axle, then ask how much it would be if you did it later by itself, then compare the prices.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
slideways... is offline   Reply With Quote
Old 01-09-2008, 03:52 PM   #3
superdesi
Thanks for the info sir. Much appreciated.
Old 01-09-2008, 08:44 PM   #4
nismo_pilot
Send a message via AIM to nismo_pilot
i would..... depending on how much more in labor he tacked on, could be trying to feed the kids
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
nismo_pilot is offline   Reply With Quote
