We have a 1988 Chevy truck 3/4 ton 4wd. The problem that we are having is that after it has been running going down the road, stop and get some gas, it won't start back up no turn over nothing like the battery is dead. The battery isn't dead, has a brand new starter, New distributor and all the insides. new battery cable. Nothing shows being wrong when the scanner is hooked up. Neutral saftey switch has been checked out. I am running out of options to replace and check, just wondering if anybody has had this problem.
Thank you.
Re: Starts cold, won't start after been running
Make sure the starter heat shield was re-installed with the new starter. The heat from the exhaust can make the solenoid not work until it cools down.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
