Old 02-18-2003, 10:17 AM
dumpedhatch's Avatar
dumpedhatch dumpedhatch is offline
heater
is there any reason it takes my heater so long to warm up. like when
I leave to goto work, I start my car let it warm up a few min, and I have the heater on the hole time. then I take off from home and when I all most get to work then my heater starts blowing out warm air. untill then its just cold air.
Old 02-18-2003, 10:30 AM
cyberrexer's Avatar
cyberrexer cyberrexer is offline
Send a message via AIM to cyberrexer
Check your coolant, it could also be your thermostat.
1991 CRX siR
1991 CR-X Si
1993 UK 2.2 4WS - FOR SALE
2005 Lexus IS200 - SOLD
1990 MX-5
Old 02-18-2003, 01:01 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Yeh if you're low on coolant you might wanna check around the hoses to see if its leakin anywhere.
Old 02-18-2003, 04:43 PM
Hatchin Hatchin is offline
Send a message via ICQ to Hatchin Send a message via AIM to Hatchin Send a message via Yahoo to Hatchin
My car does the same thing........i will run out and check
CRX Si
Old 02-19-2003, 07:24 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
It could be the heater matrix is blocked, this is basically a small radiator which the heater gets it heat from, It can be removed and then flushed out which usually makes the heater work again,
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 02-19-2003, 03:04 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Yeah...it sounds like your thermostat is stuck open...this allows free flowing of coolant, and keeps the car from heating up quickly...you should feel warm air as soon as you see the temp gauge move.
A thermostat is about $3.50...make sure you also get a gasket...the old one won't be any good once you pull the housing apart...make sure you put the new one in the same way the old one came out too The thermostat is right next to the bleeder valve on the passenger side of the head sorta in front of the dizzy I think...pop off the hose and then two 10mm bolts.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
xantia heater fan/back window heater not working alan hughes Xantia 2 02-04-2009 01:18 PM
86 Lesabre heater display lights blink/heater doesn't work Mark Spitzer LeSabre 7 06-25-2006 10:09 PM
Replaced Heater Core... now wipers, headlight, heater not working odsska Thunderbird 4 02-03-2006 01:59 PM
Block heater or no block heater darkserpant Cavalier 4 01-23-2005 11:11 AM
Heater Box/Heater Blower Resistor Block/Vac Schematic NJPagan Cherokee 1 12-14-2004 07:15 AM
