Go Back   Automotive Forums Car Chat > Car Audio
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music.
Old 12-25-2007, 04:05 PM
Tonglebeak Tonglebeak is offline
RCA A/V cable vs Coaxial RCA cable
Is there any difference in quality between using standard rca a/v cables and using a coax cable with an rca connector on it? If not I'd rather use the coax method since it's so much cheaper (being a cable tech makes this possible :P) and it's much easier to replace fittings on coax than a regular a/v cable.
1988 Oldsmobile Cutlass Ciera 2.8L V6
Old 12-27-2007, 12:26 AM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: RCA A/V cable vs Coaxial RCA cable
Don't quote me on this, but I believe quality is affected only if the material is different (i.e. gold plugs are better for quality than others). Even then, it usually isn't a big difference.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 12-27-2007, 02:52 PM
PlayStation3 PlayStation3 is offline
are the coaxial one twisted ?
Old 12-27-2007, 06:34 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
a coaxial cable, by definition, is not a twisted pair. Most RCA's are coax anyway, the problem with coax is that it's a noise antenna for freq's below 500 MHz. That means it has NO noise rejection characterisitics for audio freq's.
Old 12-28-2007, 05:14 PM
Oh forgot to mention I'm referring to RG6 cable. Center conductor is wrapped by dielectric which is wrapped by a grounding braid to protect against noise.
Old 12-28-2007, 06:35 PM
Audio Guy
yes, the bigger around the plastic dielectric is ... the more of an antenna the coax cable will be at audio frequencies. RG6 is designed for VIDEO - normal freq's are around 4,000,000 Hz, audio is 20-20,000 Hz. RG6 is NOT designed to reject noise in the audio band.
Old 12-29-2007, 05:05 PM
Alright, so conductivity won't be different. I am a cable service tech and test downstream and upstream noise constantly, ranging from 4khz to 55mhz through this tests. With good cable that has good fittings, the noise floor remains well on the bottom with no differences from frequency to frequency.
I'm just going to use the rg6. Snap-n-seal F fitting with an F-to-RCA adapter on the end, wrenched tightened. Should work out just fine.
Old 12-29-2007, 10:52 PM
Audio Guy
if you make them up and don't have noise, then everything is cool. As far as signal, copper is copper.
