B18a ?
I cant find this anywere on the web. How much HP does the B18a have?
im guessing around the same amount as the b18b
2002 Acura TL Type S 1991 Honda Crx Si |
130hp@6000rpm 121 ft/lbs@5000rpm 9.2:1 c/r
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
So it wouldnt be worth it to go with the b18b right.
b18b has like 145 hp, you would probably be alittle happier with the b18b
• DOHC 4 Cylinder 16 Valve
• Hydraulic Transmission • Displacement: 1834cc • Torque: 127 lb-ft@5200 • Horse Power: 142hp@6300 • Compression Ratio: 9.2:1
is there enough space left over to put a turbo on? or do you have to move stuff?
ENOUGH SPACE BUT YOU MIGHT WANT TO RELOCATE UR BATTERY TO THE TRUNK....WHAT ARE U TRYING TO DO?
i was thinking of getting a b18b and putting a turbo on it. I dont want to run like 12lbs boost only like 6-8lbs.
WHAT ARE YOU TRYING TO GOAL ACHIEVE OR ARE YOU WANTING TO SPRUCE UP YOUR STD??
that was the idea. should i just dump th std and get an si?
I would get an Si and go from there.
YOU CAN DUMP YOUR STD AND GET AN SI OR JUST CONVERT IT TO AN SI.....ME PERSONALLY I'M SWAPPING MY STD FOR A DOHC ZC AND ADDING A TURBO....
http://www.automotiveforums.com/vbul...threadid=85429
Thanks for the help
NO PROB
