Old 01-03-2003, 10:53 PM
walt0023 walt0023 is offline
Send a message via AIM to walt0023 Send a message via Yahoo to walt0023
Turbo Question
if i plan on runnning a 14b turbo at 6 to 10 psi will i need to upgrade my exhaust more. i have already upgraded to 2 1'4". or will that be fine for low boost like that.
Old 01-03-2003, 11:31 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Thumbs down
That's still a bit restrictive, but it's not a huge concern with low boost. You should still upgrade to 3" and that should get you a few more HP too.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 01-04-2003, 11:52 AM
91civicDXdude's Avatar
91civicDXdude 91civicDXdude is offline
Send a message via MSN to 91civicDXdude
exhaust is not that important next to upgrading your fuel and internals. you can run about 6 psi on stock internals or so i've heard, but unless you upgrade your fuel by adding a 5th fuel injector or FMU, you will lean out at full boost. a lean running engine doesnt last long, so when your engine blows because of detonation, your exhaust piping will be the least of your worries
good luck, btw
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
Old 01-04-2003, 12:14 PM
i have a fuel pressure regulator but i am going to need upgraded fuel injectors right?? what would be right for this application? i want something that will just plug in with no modification or very little. and i need a fuel pump too right? which types are good? and would i need a intercooler if i am running low boost? and last but not least, lol what kinda of power do you think i will get out of this 14b turbo?? probally running 6-10 pounds??
Old 01-04-2003, 04:38 PM
Marc-OS's Avatar
This link should help you out with managing the boost: http://www.thedropshop.tv/vafc.htm
20 GOTO 10
RUN
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
