For some time now, I have been hearing this clanking noise that appears to be coming from under the vehicle. I only hear the noise when going over bumps at about 25mph or more, & it sounds like metal to metal contact!
I tried tightening bolts under the vehicle (control arms etc.), but nothing seemed loose! The Jeep rides fine & everything functions as it should, I just can't pin point where this clanking noise is coming from? The clanking sound is not loud, & can hardly be heard with the radio on! Any ideas??? |
Re: Clanking Noise From Undercarriage?
where about under the vehicle is it coming from?
The sway bar links make a clanking noise when going over bumps when they get worn. They have a ball and socket type and wnen they wear can make a lot of noise.
I would say the noise is coming from the rear end of the Jeep, maybe the middle, but not the front.
I recently installed new front stabilizer bar links (JKS) & I keep them well lubed, no problems there. |
check the exhaust, My muffler spun a lil and was cocked sideways and was hitting, whenever I would hit bump. Go down through the whole exhaust system check all the hangers.
I'll give the exhaust a look over this weekend.
Thanks |
#7 | |
shock bolts
#8 | |
Re: Re: Clanking Noise From Undercarriage?
Check out the Catalytic Converter. It makes a clanky noise when it gets old. You can verify by turning on the car, have someone put it in gear (while holding the brake) and hit it a little. You'll hear that its loose inside. You can find them online for around $90 ish and pay about $50 to install.
#9 | |
Did you figure out the problem with the clanking? I have the same issue with my 04 Grand Cherokee.
#10 | |
![]() Join Date: Mar 2009
shake the exhaust line up down left right and front to back im sure its clanking on a bar just before the gas tank thats happens when your muffler or the catalitic converter begin to leave. and have a look for a broken coil spring and inspect gas shock too
98 grand cherokee limited 5.9 swap 249 for 242 tc 73 nova 350 powerglide 90 z-24 3.1 95 mustang 3.8 |
#11 | |
Unfortunately, I can't recall what was causing the noise. If it comes back to me I'll be sure to post back.
#12 | |
My '02 started a bad clanking on bumps randomly one morning. On a hunch and based on how the sound was, I sat on the ground on the passenger side and kicked my shoe quickly against the side of the muffler a few times. That was over a year ago and no more noise. I'll bet the exhaust hangers had just shifted a bit. Sometimes the simple fixes work...
