Go Back   Automotive Forums .com Car Chat > Fabrication & Tools > Machine Tools
Machine Tools Learn about metal lathes, milling machines and CNC tools.
Old 12-12-2007, 04:00 PM   #1
J-Ri
J-Ri's Avatar
Question Belt for metal lathe
I recently inherited a metal lathe from my grandpa. The motor is seperate and has a 3 speed belt drive. There is no way, that I can see, to remove/install the belt from the lathe side. The pulley and shaft appear to be one solid piece (maybe pressed together?), and the gear housing has a "C" shaped extension to hold the shaft.
I was in a hurry when I got it, so I cut the belt and figured I'd take the time to remove whatever part of the lathe has to be removed to change it. I looked at the belt, and saw that it appeared to have been glued together at one time. There was a diagonal line (perpendicular to the edge) through the belt that looked like glue. So I figured I'd go to the hardware store and ask for a glue-together belt. The guy looked at me like I was crazy. Does anyone know where I can find one? I don't suppose it matters, but the belt looks and feels like leather, A rubber belt would work just as well, right? This is a VERY old lathe, my grandpa got it shortly after returning home from WWII.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
J-Ri is offline   Reply With Quote
Old 12-12-2007, 05:54 PM   #2
metalmaniac
Re: Belt for metal lathe
Dont know if it is a South Bend lathe but maybe this can help you:
http://www.wewilliams.net/docs/Belt%...20No%20600.pdf
If you can't find leather for the belt I would at least try with a rubber belt.
The site where I found that pdf has more interesting things, take a look:
http://www.wewilliams.net/SBLibrary.htm
Good luck!
metalmaniac is offline   Reply With Quote
Old 02-18-2008, 06:38 AM   #3
frankthewelder
I can make a reinforced leather belt with a removable link for your lathe. It took me a while to figure it out but they last years now. you can find kits also if you are so inclined.
Turning and burning since 1984
frankthewelder is offline   Reply With Quote
Old 02-18-2008, 10:36 AM   #4
xeroinfinity
out saving the world
xeroinfinity's Avatar
Probly is a South Bend J-Ri.
I've got 2, one works and the other is parts. Not something I use regularly though.
The belts do have to be cut or like frank suggested, kits are out there for these machines.
Though they do come apart(the lathes), I dont suggest it .
1999 Grand Am SS 3.4 OHV
xeroinfinity is offline   Reply With Quote
