Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-22-2011, 05:18 PM   #1
bongobongo
2003 Z71 engine just stops and loses all power
Help! When driving with AC on sometimes my engine just quits. Bell rings and all power is gone. I pull over. Shut off everything and it will start. However, it will stop again and sometimes when I put it in park with AC on, it will stop. Have replaced fuel pump recently and had dealership put on scope and they can't find anything.
Any ideas please?!
bongobongo is offline   Reply With Quote
Old 06-22-2011, 07:34 PM   #2
j cAT
Re: 2003 Z71 engine just stops and loses all power
Any ideas please?!
clean the throttle body/IAC with throttle body cleaner. If you have PCV mounted on the driverside valve cover replace it and make sure the vacuum hoses are not cracked damaged loose fitting.
the idle issues are usually these items ...
If this was all done recently then measure the fuel pressure. 53-62 psi.
what fuel pump manufacturer did you use ? airtex is known for failure.
idle speed should be a solid 500-600 rpm..if it varies ,,,the cleaning is required..I do this about 25-35,ooomi of use.
Old 06-23-2011, 11:38 AM   #3
bongobongo
Jcat....Thank you man I do appreciate it and will try this or have my mechanic who has thrown his hands up try it....Bongo
Old 06-23-2011, 12:14 PM   #4
j cAT
cleaning this is no big deal. tooth brush,throttle body cleaner, some small tools. If you are not good at this then have a repair shop clean it. warn them not to use any carb cleaner...if used it will damage the gaskets and rubber /plastic parts..
I would get another mechanic however. I say this because this is all to common of an issue with these vehicles. since he is confused this is not good !
Old 06-24-2011, 04:37 PM   #5
bongobongo
I agree completely and thanks again. Will give this a shot and see how we do.
99 Intrigue-All 4 power windows just stopped working airdog0023 Intrigue 0 07-28-2010 11:36 AM
lumina loses all power and dies oldude Lumina 1 08-17-2008 10:55 AM
1994 Buick Lesabre, starts and runs for about 30 minutes stalls loses all power flsoutherncherry LeSabre 17 03-09-2007 03:26 PM
94 nissan pickup loses all power and shuts down... ryerye_man Older Pickups 2 07-11-2006 03:56 AM
1990 hyndai excel loses all power crashdummy007 Engineering/Technical 1 10-24-2002 09:48 AM
