Go Back   Automotive Forums .com Car Chat > Mercury > Villager
Old 11-10-2007, 07:54 AM   #1
tdc1948
'95 Villager (Quest) brake wear indicator sound?
Lately I've been getting an intermittent squeak noticeable at low speeds. It goes away when brakes are applied, and appears to be unrelated to suspension issues (i.e. bumps or glass-smooth road, still the same). Seems to be coming from a rear wheel.
I'm guessing it's a brake wear indicator telling me my pads are getting thin, but the only other time I've had a car (Buick LeSabre) give out such a warning, the sound was competely different: a fear-inducing metal-on-metal screechy squeal, not a squeak. This is definitely a squeak.
Can anyone confirm that squeak-squeak-squeak is the expected sound of the brake wear indicator doing its job?
tdc1948 is offline   Reply With Quote
Old 11-11-2007, 05:56 PM   #2
dzus
Re: '95 Villager (Quest) brake wear indicator sound?
Rear brakes don't have a wear indicator. The drums may just need removed and cleaning out the brake dust then re-adjust brake shoes. CAUTION: don't breathe the brake dust!
dzus is offline   Reply With Quote
Old 11-11-2007, 08:12 PM   #3
tdc1948
Aha - thanks! I'm not sure, of course, that it's actually coming from the rear, but I'll have a look. Does the squeak sound right for that? Or is squeak what would be expected of the front wear indicators?
Old 11-12-2007, 02:32 PM   #4
dzus
The front wear indicators will make a loud squealing noise every time the brakes are applied. Most pads will sqeak some just because of the material there made of.
Old 11-12-2007, 08:07 PM   #5
tdc1948
Right. It's not the squeal I'd associate with a wear indicator, and it goes away when brakes are applied. It's also not the usual squeak of pads. Mystery. Seems to be worse when cold. Today it was 60 degrees, and I didn't hear a bit of it.
