Old 11-11-2007, 09:53 PM   #1
igneous
igneous's Avatar
A/C compressor noise
When I turn on the a/c, getting a whining noise. If a/c is off, everything sounds fine. It's a 2001 model and wondering if it just needs an oil charge. Air blows cold and all else seems fine. I don't want to mess with the ac system if I don't have to....anyone have same situation?
igneous is offline   Reply With Quote
Old 11-11-2007, 11:39 PM   #2
Gizmo42
Gizmo42's Avatar
Re: A/C compressor noise
Should never be a reason to change oil in an a/c system.
The comrpessors on these are kinda noisy. Mine does the same thing.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Gizmo42 is offline   Reply With Quote
Old 11-12-2007, 08:54 AM   #3
mapua82
It's the A/C clutch (pulley) bearing. Nothing's wrong with the compressor.
I used tomcollin's instruction in replacing mine, skipping steps 4 & 5.
http://www.automotiveforums.com/vbul...light=harmonic
Ops, your condition was opposite of what i got before i replace my A/C clutch assembly. So, disregard my answer above.
I got a noise when A/C was OFF (compressor was disengage from pulley) and i didn't have a noise when ON (engaged).
'99 Rodeo SLE 3.2L V6
'01 Camry CE 2.2L
mapua82 is offline   Reply With Quote
Old 11-15-2007, 02:16 PM   #4
igneous
igneous's Avatar
Thanks for the advice. The compressors have a certain type of oil compatible w/ the 34a refrigerant. I only have worked on older r12 systems--
lower pressures. The both use different oil, just not sure which so I'll have to call the man.
