to convert to a digital dic you need to do the following:
on the digital dic you should have the following wires: brown ing pwr in a2 orange constant battery pwr in a1 pink ing pwr in b9 Lght blu/blk left rear door indicator a12 blk/white right front door indicator b12 gry/blk left front door ind b11 light green/blk right rear door ind a11 blk ground b4 blk ground b5 light blu engine mgt switch b7 red/blk trunk ajar ind a10 tan comp data a7 dk green vehicle speed sensor b6 lght green low trac ind a3 purple/white trac off ind a6 brn/white trac switch out b2 grey change oil ind a9 drk blu/white aux chime b1 grey pwr dimmer b3 grey/blk vf park a5 blk/white low washer fluid ind b8 on your analog dic the wires are as follows pink igintion pwr (i used this wire on both the brown and pink wire on the digital dic for ignition pwr) red/blk-trunk same as digital light blue/blk door ind same blk/white door ind same grey/blk door ind same as digital light green/blk door ind same both blacks are grounds doesn't matter which one goes to the digital blacks just hook them both up light blu same light green same purple/white same brown/white same darkblu/white same blk/white same on the two greys use a test light and hook one end up to ground and the other to a greywire. then turn on your lights and adjust the dimmer. if your test light fades then that is the power dimmer if not then it is the change oil ind and the other grey is the light dimmer and you can hook them up accordingly. for the orange batt pwr i had a plug with 4 wires taped with the harness under the dash with an orange wire that was constant batt pwr. i just spliced into it for the orange wire. for the tan wire you need to splice into the tan wire that is on the diagnostic plug and run the wire up. I did not cut the wire but used a splice connector. for the drk green wire for the vss you need to splice into the drk green wire on the back of the speedo. there are a few of them. mine was the second in next to a greyish brown wire. I didn't use the grey/blk vf park wire Mine came out of a gtp. if yours also did the trac light will say it is off but it is really on. if you press the button to turn it on it will be off. a digital dic out of a gtp will say tcs for the trac button. a digital dic out of a gt will say trac. also if your dic came out of a gt you can hook up the red wire which is for tire pressure I believe. I have had no problems with my new dig dic since converting over. I hope this helps anyone else interested in doing this |
Re: converting analog dic to digital drivers info center
If anyone knows what the grey/black vf park wire is for would you please let me know. Thanks
thanks alot!! I've been wanting to convert over, but I had no clue what wire was for what. I think this should be made into a sticky. Also, does it show you your gas mileage correctly? Thats the main reason I want it.
2003 Grand Prix GT 1993 Cavalier 2.2L |
Mine shows fuel used, mpg, estimated range and oil life. mpg has been working correctly as far as i can tell. any other questions just ask and i will help if i can
thats great, and you didnt have the second wiring harness? you wired it in seperately? where did you get your dic?
off ebay. I have an extra one . if you are interested in it let me know otherwise i will put it on ebay. I paid 99.95 for it. it is out of a 1999 gtp to answer your question there was no second harness to be found. i looked everywhere
yourpappy, you got it to work? How long did it take? Where did you find the wires to splice into fr the ones that arent wired to the analog DIC?
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
as described above the orange wire which is a constant bat power wire i spliced into from a 4 pin connector that wasn't used taped to the dic harness under the dash. the green wire for the vss i spliced into from the back of the speedo. the tan wire which is a data wire i spliced into where the diagnostic plug is. I did not cut any of these wires but used a crimp on splice connector. it took about 2.5 hours. what took the longest was finding the right green wire on the back of the speedo.
Has anyone else attempted this swap? I have no problem moving the proceedure to the "tips and maintenance" subforum if it works.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Rich, I was going to try and do it to my girls grand prix se, but we havnt found a digital DIC from a gt and a harness yet. If I do attempt it, I will snap some pictures of the mod.
I have to change a light bulb in my dash in the next few days. When I do I will take some pics of the wires I spliced into on the speedo and the diagnostic connector for you.
thanks!!!!
