Old 03-23-2010, 10:39 PM
OldMan9 OldMan9 is offline
Unstable RPM Idle
I took out the AIR CONTROL VALVE and cleans it w/BRAKE CLEANER. I started the car up and after driving for 15 minutes the high Idle has gone down a little and I wonder why it didn't stop the unstable RPM idle completely????? HELP. thanks
Old 03-24-2010, 12:09 AM
cherryelky305 cherryelky305 is offline
Send a message via AIM to cherryelky305
Re: Unstable RPM Idle
whats the issue? by unstable do you mean it revs up high then down low, in a repetitive pattern? If thats what its doing, then its the IAC valve (idle air control valve)
you said you cleaned it but it might just be flat out bad, check it again. If it visually looks ok, but you still have an issue buy a new one.
1980 El camino
2002 LS1 swap
Old 03-26-2010, 04:25 PM
Smile Re: Unstable RPM Idle
Yes, I now ordering a new IACV and still waiting for the part; but i do appreciated your help. Thank you.
Old 03-27-2010, 10:52 PM
Unhappy Re: Unstable RPM Idle
Originally Posted by oldman9 View Post
yes, i now ordering a new iacv and still waiting for the part; but i do appreciated your help. Thank you.
i just installed a new iacv (idle air control valve) onto my car and the problem is still the same...............i did do all the air, fuel hoses cleaning and even put a bottle of (sea foam) fuel injector cleaner to clean injectors and fuel lines but the problem doesn't to go away............
