Old 10-24-2007, 09:25 AM
jeddi20 jeddi20 is offline
2001 454 crank sensor
my friend has a 3500 and the cranksensor keeps going out and frying the starter. he has replaced the sensor and traced all the wires back to the ecm. it will run for a while just fine. he'll shut it off and come back an hour later and it sounds like its trying to backfire when cranking. if you disconnect the sensor it spins normally but no fuel or fire.
Old 10-24-2007, 09:52 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2001 454 crank sensor
A sensor disconnect is not a very good way to test it.
Any codes being set.
Check secondary ign.
Start with cap and wires and rotor and dist and plugs.
MT
Old 10-24-2007, 12:04 PM
no codes are being set. the entire secondary has been replaced.
