96 Silverado - Bosch Fuel Pump
I'm replacing the fuel pump on my 96 Silverado (as a precaution) and I've got a few to pick from. I'm leaning towards a Bosch which is supposed to be an improvement over the original pump, and its rated 34PSI.
Another lesser name pump for a few bucks less is rated 24 PSI. I'm not sure what the original pump is rated for in terms of PSI, but is this a potential problem? Would it make fuel leaks more likely? Any performance issues with a higher pressure pump? Appreciate any feedback. Thanks |
Re: 96 Silverado - Bosch Fuel Pump
First, I wouldn't replace it unless you are having problems with it. Why spend money and time on something you don't need to do?
But if you are set on doing it, don't use anything other than an OEM (AC Delco) pump. From what I hear all aftermarket pumps are junk. I replaced mine with OEM when my check valve went bad and it works like new.
2002 1500 Ext. Cab 4.8L 2wd. K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights. |
If it aint broke dont fix it
I am with rjeffery, only replace when needed, and only with an oem pump. You will have better luck. After working at an auto parts store and selling a few different brands, oe is the only way to go.
NO 4 N JUNK ![]() 1994 GMC K1500 XC 5.7L 2008 Chevy Impala LTZ |
