Old 09-07-2005, 07:42 PM
starla3366 starla3366 is offline
Send a message via Yahoo to starla3366
IF YOU DISCONNECTED YOUR BATTERY-Click Here for Instructions on: HOW TO IDLE-RELEARN
HOW TO RE-LEARN THE IDLE
If your battery has been disconnected for any reason, you may need to perform this procedure in order for the computer to relearn how to idle. Under most circumstances, it will relearn after just driving the car for a while, but if your car continues to experience an abnormal idle, or you just don't want to wait for it to relearn on its own, you can try this procedure.
STEP ONE:
Disconnect the Negative cable for a few minutes. While The negative cable is dissconnected, pump the brake pedal a few times to clear out any voltage in the system. Re-connect the negative cable after this is complete. Turn off air conditioning controls and all other accessories.
STEP TWO:
Run the engine up to operating temperature and shut off.
STEP THREE:
Apply the parking brake. Start the vehicle and place it in drive (A/T), or neutral (manual).
STEP FOUR:
Run the engine until the cooling fan has cycled on and off, or for a maximum of 10 minutes.
STEP FIVE:
Turn the ignition key off for at least 5 seconds.
STEP SIX:
Restart the engine and again shift into drive or neutral. Allow engine to run for at least 5 minutes.
STEP SEVEN:
Shut off engine for 10 seconds and restart.
STEP EIGHT:
That should do it. With engine stabilized and in closed loop, the IAC motor values should be between nine to 12 counts. If not, the adjustments may be tailored by adjusting the minimum air rate screw. More throttle valve opening equals lower IAC counts. Less throttle opening equals higher IAC counts.
2000 Blazer LT
4.3 vortec
75k miles
K & N FIPK
Old 09-08-2005, 09:23 AM
RotorBalls RotorBalls is offline
Send a message via AIM to RotorBalls
Re: Click Here for Instructions on: "HOW TO IDLE-RELEARN"
Great info, wish I had this info when I had the problem.
Old 09-09-2005, 01:31 AM
zephram22's Avatar
zephram22 zephram22 is offline
Send a message via AIM to zephram22 Send a message via Yahoo to zephram22
Originally Posted by starla3366
THIS NEEDS TO BE A STICKY!!!!!!!!!!!!!!!!!!
STEP ONE:
STEP TWO:
STEP THREE:
STEP FOUR:
STEP FIVE:
STEP SIX:
STEP SEVEN:
STEP EIGHT:
That's a good thing to know.
1963 Triumph TR3 12K
1995 Buick Century Special 178K
1999 Chevy Lumina LTZ 160K
2001 Suburu Forester 53K
2002 Oldsmobile Aurora 3.5 45K
2004 BMW Z8 3K
2005 Dodge Charger .5K
2006 Jaguar XJ12 1K
Old 09-17-2005, 01:14 PM
robrieke robrieke is offline
Re: Re: Click Here for Instructions on:
Here's something I found in my Haynes to help provide some more guidance. Instead of typing a long paragraph, I'm going to put into steps.
1. Start the engine and run it as close to idle speed as possible until it reaches its normal operating temperature.
2. Run it for approximately 2 minutes at 1200 RPM.
3. Drive the vehicle as far as necessary, approximately 5 miles of varied driving conditions is usually sufficient to complete the relearning process.
Robert A. Rieke
Old 10-14-2005, 01:55 AM
ocjmakaveli ocjmakaveli is offline
Can you please tell me how to check the counts of the IAC? for a 92 lumina my lumina jsut started stalling at low speeds and I can figure it out at all.
Old 11-22-2005, 11:31 AM
zephram22's Avatar
Thanks for posting this. It's very helpful!
2004 BMW Z8 3K
2006 Jaguar XJ12 1K
Old 12-10-2005, 10:26 AM
fastlq1 fastlq1 is offline
My friend that does performance chips for the 88-94 FWD cars has me do it different on my 91 & 92 Z34 5 speed cars.... Pull ECM fuse for about 30 sec., put it back in, turn key to ON but do not start for 5 sec., turn it off, turn it ON again for 5 seconds but do not start, then start it... So far for the last 3 years I have never had a problem doing it this way.
Old 01-20-2006, 05:13 PM
Mediaman67 Mediaman67 is offline
will the ECU/IAC "learn" over many weeks, or will in never re-adjust, until you do what you are saying to do...
The problem I have, after the car warms up, you can hear, and see on the tach, it doing a periodic "bounce" down from 900 rpm, or whatever it's supossed to be idling at all the time when warm. The car never stalls, because it recovers very quickly, but I didn't know if this was an indication of a failing IAC motor?
The car never does this when given gas... the tach is steady. I have replaced the Ignition Module a year ago, as this did go bad (tach would bounce all over the place at times, and stall the engine when really warm, etc)
How can I Trouble shoot this, or is this a classic sign of a failing IAC motor? It's easy enough to replace, but I don't want to do it, unless it is what is causing the problem for sure. - Again, not bad enough to stall the car... but I hate seeing the tach do that... doesn't idle rough or anything... just does that dipping...
Thanks
Old 01-25-2006, 08:39 AM
Carwhiz Carwhiz is offline
If all else fails, go to the gm garage and have the idle reset. aproximately $30, 1/2 hour labor. The only cars that SHOULD need this are early 90's gm's. All current cars SHOULD reset themselves.
Old 02-10-2006, 12:18 PM
Anizalb1288's Avatar
Anizalb1288 Anizalb1288 is offline
how early does a car have to be for this procedure to be necessary?i have a 94 lumi, does it require a manuel idle reset or does it do it itself?
thanks for getting back to me on this in advance.
True greatness is but an idea, attainable only after death.
Old 02-13-2006, 09:35 AM
hey does anybody know what years of lumies this idle reset applies too?
Old 12-29-2006, 03:22 PM
airboatphil airboatphil is offline
I have learned that cleaning the throttle body before starting up after a battery disconnect helps tremendously !!! No creeping idle...no nothing !
Phil
Old 09-20-2007, 09:11 PM
Herbstleyd's Avatar
Herbstleyd Herbstleyd is offline
Send a message via MSN to Herbstleyd
Question Re: IF YOU DISCONNECTED YOUR BATTERY-Click Here for Instructions on: HOW TO IDLE-REL
STEP TWO:
STEP THREE:
Running the engine up to operating temperature
Do you mean driving (or let run in the neutral) until the fan start ?
Thanks
Guillaume
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
Chevrolet Lumina Z34 1991
250 000 KM, second engine
3.4L DOHC DUAL TWIN CAM
5 Speed Manual
Cone Filter & Big Exhaust
Old 09-21-2007, 05:36 AM
maxwedge maxwedge is offline
A990 racer
This thread is too old, btw in neutral
