Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 08-28-2005, 12:28 AM   #1
rmartens
1999 Neon shakes & jerky at 50 mph
Works fine at lower speeds , seems to me like it's slighty (jerky) losing power at 50-55, shakes, runs better at 60mph.
rmartens is offline   Reply With Quote
Old 08-28-2005, 10:24 AM   #2
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 1999 Neon shakes & jerky at 50 mph
It could be your lower control arm bushings need to be replcaed. However, here is additional information which may help cure the problem without replacing the bushings:
The Neon is *very* sensitive to wheel balance. Have your wheels rebalanced to the nearest 1/8 ouce instead of 1/4 ounce, and make sure the machine has been calibrated recently.
Make sure that your tire pressures are even between the two front tires.
If you have aftermarket wheels there is some other things you can do.
das2123 is offline   Reply With Quote
