Old 08-29-2007, 08:30 PM
aphinney aphinney is offline
Send a message via AIM to aphinney Send a message via MSN to aphinney Send a message via Yahoo to aphinney
Crx Problem..need Help Fast
i have a 1990 crx si....1.6L...everything factory in this crx...the other crx is my baby....the si is my daily driver...but anyways..i was driving it to work and everything i shift and press the acc. it suputters bad...then it will take off when i let off the gas a bit...feels like it is like flooding itself...
COULD THIS BE...
distributor, spark plugs, injectors, i was told by a guy that has 4 crx's that it is the...TPS ( throttle positioning sensor )
HELP GUYS..thanx in advance
TEAM AUDIOHYPE
1990 Honda Crx SI
Old 08-29-2007, 10:23 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Crx Problem..need Help Fast
Yup. sounds right..mine did it exactly like that..the ground wire had broken off the plug. check the ecu for a code 8.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 08-29-2007, 10:56 PM
so u think it is the plugs or the TPS
TEAM AUDIOHYPE
1990 Honda Crx SI
Old 08-30-2007, 09:22 PM
well it isnt the TPS.....checked the oil...and it is a QUART over the full line...JIFFY LUBE messed up big time....u think that could be the prob ?
TEAM AUDIOHYPE
1990 Honda Crx SI
Old 08-30-2007, 10:35 PM
FrodoGT's Avatar
i dont think a quart would kill you, or do that. If your crank is dipping into the oil then yeah it would make the engine run like its pumping mud..but it would also whip up your oil into a nice froth...you may wanna drain it and check if your really worried..OR just drain the extra quart.
Current project:
Rio Red 91 hatch.
Old 09-03-2007, 07:10 PM
well idk what the prob is...could it be that my muffler is clogged and it is gettin too much back pressure...or what cause i have tried everything but new plugs and distributor...havent changed the tps but checked that and it is fine
TEAM AUDIOHYPE
1990 Honda Crx SI
Old 09-03-2007, 07:22 PM
Hybrid1990crx's Avatar
Hybrid1990crx Hybrid1990crx is offline
Send a message via AIM to Hybrid1990crx
what exactly did you do? are you throwing a check engine light?
Saturn Stealership Technician #331
Old 09-03-2007, 08:38 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
check your fuel filter, see what the fuel looks like that is coming to and out of it. Sounds like you might be getting some bad fuel in it. If the gas going to the filter looks bad, go back and check the sock on the bottom of the fuel filter, it could be stopped up.
Had this happen sooo many times when I was at the salvage yard, and thats exactly what it would do. You hit the gas and it sputters, let it and it seems to do a little better. Everytime it was the gas.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 09-03-2007, 11:49 PM
FrodoGT's Avatar
Lift up the carpet under the passenger side footwell and count the blinks if there are any, my bet is there are 8.
Current project:
Rio Red 91 hatch.
Old 09-04-2007, 03:09 PM
if there is 8 what is that ?
TEAM AUDIOHYPE
1990 Honda Crx SI
Old 09-04-2007, 03:52 PM
FrodoGT's Avatar
top dead center sensor.
A 7 isnt too unlikely either. and thats the tps
Current project:
Rio Red 91 hatch.
Old 09-04-2007, 05:52 PM
thanx again..but u are talkin to a honda newbie....what is top dead center sensor?
TEAM AUDIOHYPE
1990 Honda Crx SI
Old 09-04-2007, 07:02 PM
i think he means the crank sensor. ive never heard of a tdc sensor.
Old 09-04-2007, 09:51 PM
FrodoGT's Avatar
http://www.automotiveforums.com/vbul...30&postcount=5
http://www.car-forums.com/s15/t17291.html
Current project:
Rio Red 91 hatch.
Old 09-06-2007, 05:50 PM
Thats straight from Alldata.
If you can't read it i'll try to resize it. Its the same thing.
