Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 10-22-2007, 01:43 PM
Phil0968 Phil0968 is offline
Send a message via AIM to Phil0968
Engine wont turn over
When I turn the key in the ignition all i hear is a click. Not sure what the problem would be, i know it is not the battery because it was just replaced 3 weeks ago. Would this be due to a faulty ignition switch or some other problem. Any help would be appreciated
Old 10-23-2007, 02:13 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Engine wont turn over
b/c I dont know what kind of rig/mile-age u have, I suggest first to check this (guess its Nissan) http://www.cardomain.com/ride/748507/5 - see also pages 10 & 23
Typically this nostart with click is: bad contacts, worn starter brushes, solenoid -and/or- charge problem.
Old 10-23-2007, 11:58 AM
my car is a 97 SE automatic with a 100k miles on it.
Old 10-23-2007, 11:58 PM
Bypass test, after checking the thick gnd and plus batt wires and batt voltage:
Theres the solenoid hot ctrl wire (with plugin connector). Find spare wire, push its bared end into solenoid side plug, touch plus batt pole with other end. Solenoid kicks in and starter will turn (if starter&solenoid is ok). If not, repair/replace.
Old 10-26-2007, 08:50 AM
BeZerK2112's Avatar
BeZerK2112 BeZerK2112 is offline
380HP Isn't Enough...
Just because you replaced your battery dosen't mean you got a good one. Some the batterys people buy can sit on the shelf for months or even years. If you have a volt meter check the charge of your battey. It should be around 12.60 volt on a full charge. Jump start the car, and remove the cables. Now your car should be producing 13-14 volts. If it isn't you possibly have a bad alternator. If your car stays running take it to any auto parts store and they can check all this for you.
Good luck
WHAT KEEP IT STOCK! Well that takes the fun out of it.
[center]
99 Maxima - View the Project at CarDomain
