Old 04-06-2006, 03:53 AM   #1
jamesmetairie
light reads = change oil soon
light still on after fresh oil change. advice will be appreciated. thanks.
jamesmetairie is offline   Reply With Quote
Old 04-06-2006, 09:11 AM   #2
Daghara_terry
Re: light reads = change oil soon
If you just changed oil and it's still on ad some "Lucas" oil treatment and it will turn it off. The sensor triggers when oil pressure is low. The lucas will raise the pressure while making the oil thicker.
Daghara_terry is offline   Reply With Quote
Old 04-06-2006, 09:55 AM   #3
Manny_boy
Manny_boy's Avatar
What year is your lumina - if its a newer lumina, its not the oil pressure. The Change Oil Soon telltale is for useable oil life based on mileage. The indicator has to be reset.
KOEO (Key on engine off), press your accelerator pedal to the floor three times (the Change Oil Soon light should flash (IIRC)) turn the key off - it should reset itself.
Behind a calm face is a disturbed mind controlled by music...
Junkyard Dog - Be careful...it bites!
Manny_boy is offline   Reply With Quote
Old 04-06-2006, 10:01 AM   #4
bleepster
manny is spot on
low oil pressure is a RED indicator light
bleepster is offline   Reply With Quote
Old 04-06-2006, 08:17 PM   #5
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Look. Not knowing what you are talking about is one thing. We all gotta learn. But throwing out ridiculous ideas as if you know what you're talking about when people need help is careless. Stick around and learn, but try to restrain yourself. Please.
...empty gun rack.
Old 04-07-2006, 02:10 PM   #6
Daghara_terry
Don't talk shit the same fucking thing happened to me and thats what I was told to do and it worked for me and if such a fuckin maechanic then what the hell are you doing with all this time on your hands to make almost 2000 post you need to get a life from some of your post you sound like you know what your talking about a little but where are you getting your info Chiltons car manual because its sure not first hand knowledge. So eat that and don't be dissin' people.
Old 04-07-2006, 04:41 PM   #7
jeffcoslacker
Does your mommy know you talk like that to people on the internet?
...empty gun rack.
Old 04-08-2006, 12:21 AM   #8
Myxlplyxxx
Yes the light needs to be reset after the oil change... car off/ ignition on... gas pedal 3 times ..turn off.. easy as that ... trust is the key word here... call yer local quik change place or yer dealer and ask them... I GUARANTEE they will tell you the same thing as I have along with (manny boy and Jeffco) Ive done mine several times...NEVER FAILS... Oh and Terry... I would trust the guys who know what they're talking about over someone who just Joined... NO Offense....
Good Luck
MYX
Myxlplyxxx is offline   Reply With Quote
Old 04-08-2006, 07:37 AM   #9
Hearts88
I have a '99 Lumina. Manny boy is right. In my owners manual it says exactly what he said. Just make sure you press the gas pedal 3 times within 5 seconds. If you do it too slow it won't work. Be patient. You may have to try a couple of times.
Lucas Oil for a change oil soon light.
Hearts88: 2cents:
Hearts88 is offline   Reply With Quote
Old 05-23-2007, 06:52 PM   #10
spdfrk1990
Thanks im sure that is why mine comes on it goes off after a min tho is that usual?
spdfrk1990 is offline   Reply With Quote
Old 05-23-2007, 07:52 PM   #11
richtazz
stupidity should hurt
richtazz's Avatar
Hey Daghara, Jeff's a moderator and can ban you, you potty mouthed little punk. All he was doing was straightening you out. A low oil pressure light is way different than change oil soon. Read posts thoroughly before you make suggestions. Those of us on here with high post counts know what we're talking about...you... not so much.
Old 05-27-2007, 05:14 PM   #12
gw84
gw84's Avatar
Send a message via MSN to gw84
I gotta ask the same thing that spdfrk1990 asked but never got a response to... Is it normal for the CHG OIL SOON light to come on when the car is started then go off after a minute or so? I did the reset procedure but it still comes on at startup then goes off after about a minute. thanks
This ain't your grandma's car!!
gw84 is offline   Reply With Quote
Old 05-27-2007, 05:20 PM   #13
spdfrk1990
I did the reset and it fixed mine .
Old 08-11-2007, 01:40 PM   #14
ilovemytracker
Yeah, that is normal. I have a 97 Lumina that will do that when it is getting close to an oil change. It will do that for about two weeks before going to a steady on. Once changed, just reset the light like described above and your good to go again. Of course, as far as having already done the reset procedure and it is still coming on, I have never had that happen.
ilovemytracker is offline   Reply With Quote
