95 series 1 computer+modules question
im swapping 3.8 sc engine into my alero but i was wondering what modules are in the riviera so i know which module to get and not get. im thinking about maybe making it a little easier to get the speedometer cluster/gauge cluster though im really not sure.
99 olds alero 2.4 DD 92 notchback with 460 carb'ed |
Re: 95 series 1 computer+modules question
anybody know?
try asking here- rivperformance.com
but most people dont swap a series 1 engine :scratch: the series II is cheaper and easier to find |
Ok, one thing for sure, you will need the original ECM & prom from the donor car. You cannot mismatch engine & Trans control with any other ECM/PCM. They are all unique in how & what they control. In addition, the wiring harness is a dedicated part of the combination. You will need both!
Knowledge can be communicated, but not wisdom! ![]() ![]() |
so which one is the ecm and pcm then. which numbers would show me which ones was which on is there big size difference. i did take out all the modules out of the junkyard and iirc 1 of them was really big one fit in the palm of your hand one was like 3 inches smaller than the big one.
From your original post, it was not clear what your intentions were when changing engines or PCM’s, so I will try to clarify this a little more.
If you have a 95 Series I PA (L67) engine/trans and a 95 Series I (L67) Riviera, the PCM should be compatible. They both carry a Part #16183247 PCM. What would not be compatible, is an OBD I or OBD II PCM or different year PCM for the Series I or Series II engine. The PCM wiring pin-outs and programming are different for every year from 92-95. All 96 & newer models are OBD II, and not compatible with any of the earlier years!
Wait a minute! Let’s not confuse the PCM/ECM with the ECBM! First, the earlier computer controlled cars (85-95) used an Engine Control Module (ECM) that was located inside the car on the passenger side, behind or above the kick panel. These units were fitted with an internal PROM or chip to control engine functions then later were used to control the engine and transmission. As the computer systems progressed, the Power Train Control Module (PCM) replaced the ECM on some 95’s, then in 96 and newer cars, they all used a “PCM” (OBD II). These two similar computers perform some of the same functions, only the PCM is much more sophisticated and does not contain a replaceable prom. Now, you also have the Electronic Brake Control Module (ECBM) that is a different animal all together. The ECBM is used to control the ABS brake system. Usually the ECBM is a smaller box located near the firewall and under the power brake booster. Finally, somewhere in the mid 90’s, they also installed a Body Control Module (BCM), however it is usually located under the dash or under the seat. I hope this helps eliminate some of the confusion.
is getting the gauge cluster work the effort or not?
Sorry, I don't know enough about the gage cluster compatibility to comment on that.
Click Here for view of ECM/PCM
Click Here for view of AC Programmer Are these the two modules you have? BTW, I almost forgot the Body Control Module (BCM) that is a Part # 25646511 and also contains the Anti Theft controls.
Knowledge can be communicated, but not wisdom! ![]() ![]() Last edited by HotZ28; 07-21-2007 at 01:49 PM. |
