Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 06-27-2007, 04:00 AM
1987 CRX HF 1987 CRX HF is offline
1987 CRX HF engine swap!!! Please HELP
I have been looking all over online and i have found nowhere where it talks about people who have swapped a d16/b16a1 into a CRX HF carburated.
I know i need to wire in fuel injection but im relatively new to this and if there is anyone out there who knows about doing this or is good with wiring harnesses then please help
Old 06-28-2007, 04:42 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: 1987 CRX HF engine swap!!! Please HELP
You need a conversion harness like one from Hasport.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 06-28-2007, 11:55 PM
so do i even need to wire in fuel injection from an SI? Because the harness that i would need for the B16a1 swap says to swap from a 87 SI crx.
so all i need to do i just get the fuel injection wired in and then go from there?
Old 06-29-2007, 12:27 AM
NA is Best!
Yeah get your car set up like the Si and as far as I know from there it's plug and play.
Old 06-29-2007, 05:50 PM
1gcvcb18's Avatar
1gcvcb18 1gcvcb18 is offline
You can not use 87 civic si harness for a b18. You can use it for a d16a1. I would be easier to swap out the engine from an 86-89 integra into the crx with wiring harness and hubs and front brakes. just buy a integra for cheap cheap price and strip it down and put the engine in the crx. If you need for info on what to do check out redpepperracing.com or check out my gallery at the end of my message
84 Civic DX D16A1 Swap (in the making)
http://www.redpepperracing.com/gallery/v/1gcvcb18/
Old 06-30-2007, 11:15 PM
but im not putting in a b18
im putting in a b16
Old 06-30-2007, 11:33 PM
I just decided to go with the d16a1
It just too much of any investment for the b16
it would cost me about 3600 dollars
besides i can just buy a 91 crx si with the b16 in it with that kind of money
so alll i need to do with the d16a1 swap is:
86-87 SI
intake manifold
ECU
fuel lines
fuel pump
fuel tank
wiring harness
d16a1 engine from an 86-87 integra
suspension
right?
Old 07-01-2007, 10:47 AM
1gcvcb18's Avatar
86-87 SI
intake manifold
ECU
fuel lines
fuel pump
fuel tank
wiring harness
suspension
right?
If you can find a 88-89 integra it would be best, it has electrical advance versus 86-87 that is vacumm advanced thisa is if you choose to chip the ECU or turbo it. Just us the same thing you said for the 86-87 and you will need the hub assembly with the axles and brake system. You can also convert the rear end to disc brakes also using the the teg's one. if you need any help with any of this let me know.
Old 07-01-2007, 03:56 PM
well i just talked to a local junkyard and they have a complete 86 integra and they are willing to sell me everything i need for the swap for 800 dollars
and thats the only 86-89 integra engine in the area so i pretty much dont have a choice but to go with the 86
my main concern at the moment is the wiring harness...
i dont know how to wire my crx hf to support the CRX si wiring harness because the plugs and stuff are different
any help there?
Old 07-01-2007, 09:03 PM
1gcvcb18's Avatar
Ask the local junk yard if they will sell you the teg wiring harnes and just swap it out. This is the best and fastest way to do it. I wnet the hard way and used the 84 dx harness and added the 87 teg harness this is a bitch to do. and at the end of all of this i had to do i found out that i could of just swaped the harness, just remove the wiring for the headlight motors on the teg and your good to go.
Old 07-02-2007, 01:37 AM
im gonna need to go check it out myself and see whats up becasue i havent been able to even see it yet.
well as far as i see the swapping of the harnesses isnt all that difficult so i will have to see
ill try and go tomorrow and ill get back with you on what i find
Old 07-04-2007, 10:39 AM
1gcvcb18's Avatar
check out my foto gallery and you will have an idea of what is needed to make the swap happen
Old 07-04-2007, 03:12 PM
ok sry but im sort of new to the whole swapping engine thing but
when it says remove the wiring harness...that means remove all of the wiring behind the dashboard right?
Old 07-04-2007, 04:51 PM
1gcvcb18's Avatar
Remove all the wiring in the car under the hood and the trunk.
Old 07-05-2007, 10:44 PM
well i should be doing the FI swap in about 2-3 weeks or so...ill make sure to take plenty of pictures for anyone that is looking for any info on the topic
