Old 06-26-2007, 07:07 PM   #1
yhandor
yhandor's Avatar
Send a message via MSN to yhandor
Code P0113 Intake Air Temp Circuit Hi Input
Hey, I jsut got my replacement engine in, used of course, and runs fine andeverything but I am getting the code p0113, Intake Air Temperature Circuit High Input, where can I find this on a 97 2.4L twin cam? and what exactly is it? the mass air flow sensor in the air intake tube? Thanks!
yhandor is offline   Reply With Quote
Old 06-27-2007, 03:28 AM   #2
Ronnie_1981
Re: Code P0113 Intake Air Temp Circuit Hi Input
You don't have a MAF sensor, you have a MAP sensor, It will be a little thing sticking outta the intake piping. But i don't think your IAT sensor is your problem, let me sleep on it and I will get back to you.
Ronnie_1981 is offline   Reply With Quote
Old 06-27-2007, 09:11 AM   #3
yhandor
yhandor's Avatar
okay thanks
Old 06-27-2007, 03:37 PM   #4
Ronnie_1981
According to the GM service manual, if the IAT sensor is out it will throw this code, so I say replace it, and see if it give you anymore trouble. It is 12 bucks at advance and a hell of alot cheaper then any other problem it could be so sounds like a good place to start.
Old 06-27-2007, 05:14 PM   #5
yhandor
yhandor's Avatar
Where is it on the motor though...
Old 06-30-2007, 03:48 AM   #6
yhandor
yhandor's Avatar
anyone?
Old 06-30-2007, 10:46 AM   #7
jakegday
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
somewhere along your intake
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
jakegday is offline   Reply With Quote
Old 06-30-2007, 01:27 PM   #8
yhandor
yhandor's Avatar
Shit I need to know, because I think tis is why Im having bad mileage.
Old 06-30-2007, 04:29 PM   #9
Ronnie_1981
we have told you it is in your intake piping, goto the parts store and pick you one up, then come home and look in you intake piping for it.
Old 06-30-2007, 05:12 PM   #10
yhandor
yhandor's Avatar
I dont know where that is? My cold air intake pipe? the sensor that goes in there is a mass air flow sensor isnt it?
Old 06-30-2007, 09:19 PM   #11
dwb985
the 2.4 does NOT have a MAF (Mass Air Flow) it has a MAP (Manifold Absolute Pressure). the first sensor on your intake the one right after the filter is the IAT. the one that was a bitch to put in you must unplug it and pull it out put the new one in gently they break if you just jam them in then just plug it up clear the code and if nothing else is wrong you should be fine. oh and it would be the cause for bad MPG it helps in deciding how much fuel is needed based on the temp of the air going into the engine.
dwb985 is offline   Reply With Quote
Old 07-01-2007, 02:51 PM   #12
jakegday
yes, it would be the one in your cold air intake pipe, and no, that is not a MAF sensor, as already stated, your car does not have one of those
and without your IAT sensor working properly, the computer will go into some default mode and will use more gas
Old 07-02-2007, 09:43 PM   #13
yhandor
yhandor's Avatar
alright ill let you know. thanks :P
