Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Old 05-21-2007, 01:42 PM
pathfinderrs pathfinderrs is offline
99 Pathy turns but won't start
I have a 99.5 pathfinder SE. When I turn the key the engine has a strong crank, but just doesn't start..and doesn't even seem like it wants to start.
- battery and alternator are good.
- checked the fuel pump by just turning the key 3/4 and listening for the pump hissing noise, which was there.
- fuel tank is full and I pinched some fuel lines before the injectors and they seem pressurized.
Any ideas if my problems are with the alternator/rotor etc and how about I can test?
Thanks.
Old 05-21-2007, 06:01 PM
Re: 99 Pathy turns but won't start
Today...I tried starting it and on the third try after depressing the peddle it started. I drove it for about 30 minutes to charge up the battery and then stopped it. When I tried to restart it a few times...it wouldn't start, but then it started. I was then able to start it a few times thereafter.
Any idea why my truck is no longer reliable when starting? It still had a very good crank when turning the key, so I expect the batter and alternator are fine..and I do still hear the whinning noise when I turn the key 3/4 and listen for the fuel pump?
Old 05-21-2007, 06:18 PM
Scrapper Scrapper is offline
AF Premium User
fuel pumps you might hear them but it don't mean it got enough fuel presure..try this when it wont start spray some starting fluid in it and if it starts you know it's not getting gas or the right spark..
Old 05-21-2007, 06:28 PM
ok thanks scrapper. I'll give it a try. Thanks, I didn't realize that a fuel pump can work, but just not as required to.. I figured either it worked or it didn't.
If it was the distributor cap and/or rotor parts....would they allow the truck to start intermitantly or would it just stop all together?
Old 05-21-2007, 06:29 PM
88pathoffroad 88pathoffroad is offline
Send a message via ICQ to 88pathoffroad Send a message via AIM to 88pathoffroad Send a message via Yahoo to 88pathoffroad
Is the check engine light on? You can have your error codes checked free at most any local auto parts store.
88 XE V6 4x4, 33x13.50 Swampers, 6" lift, winch, etc etc etc
Admin of NPORA, Moderator for NPM, AllNissans.com and NissanHelp.com forums
Old 05-21-2007, 06:31 PM
When I am able to start it...there isn't any check engine light on? Thanks...I didn't realize this...I'll go to a parts store and ask them.
Old 05-21-2007, 08:10 PM
I tried starting the pathy a few times about 5 hours later than when I first tried today and it didn't start. It seemed that when I kept the peddle down and then turned the key 3/4 for a few seconds and then full turn to start...it seemed like it was going to start but then it goes back to just a dead crank?
frustration....can anyone help.
Old 05-24-2007, 08:32 PM
It's difficult to impossible to diagnose starting problems over the internet with no pics, data or history. It could be any number of things.
Old 05-26-2007, 01:20 PM
Well I hear the fuel pump whine when I turn the key.
I checked the first spark plug for spark on ignition and there is.
I changed all 6 spark plugs.
I changed the air filter.
I don't see any "service engine soon" light come on...so I assume it isn't a sensor.
It starts some times and then other times not.
Cleaned Throttle body.
Not entirely sure, but it seems to have trouble when engine is hot...but can't confirm this as always being the case.
Still having some trouble starting at times?
They say its either fuel, spark or compression?
Old 05-31-2007, 07:23 PM
corvair corvair is offline
try spraying a bit of "O2 sensor safe" carb/throttle body cleaner into the intake. crank her over,if it fires up you have a fuel delivery prob.
Old 05-31-2007, 09:36 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
Sounds like you may have an injector stuck open and flooding it out, thats why when you have the gas pedal to the floor it tries to start or starts. If you put a fuel pressure gauge on it, Fuel pressure should be around 36 psi. After you shut the truck off or after you stop cranking. Watch the fuel pressure see how fast it drops. It should hold fuel pressure at 36 psi for at least 5 mins maybe more. Feel free to ask me any more questions.. Gl
Old 06-05-2007, 05:07 PM
Last night when I tried starting it...it wouldn't. Tonight I tried starting it and it wouldn't at first but I dropped the peddle and then cranked it and it seemed to want to start. After a few tries, I didn't touch the peddle and it started? I'll try to put the fuel pressure gauge on it tonight.
Old 06-14-2007, 05:00 AM
redmansioner redmansioner is offline
Banned
Have you checked the spark plugs already?If the fuel injector is okay then it could probably inside your nissan engine problem.
Old 06-17-2007, 03:29 PM
Distributor, rotor, cap, wires, spark plugs have been chnged. Brought it to the dealer...ran a scan checked everything looked fine. Fuel pressure was good.
Anybody have the same problems?
Old 06-20-2007, 08:37 PM
flabigboy flabigboy is offline
I have the same problem on a 98 with a 3.3 liter engine. I came home went to start the car 20mins later it kick spluttered back fired then died. It kept turning over but wouldn't start. I changed the crank position sensor which is easy if your wife has small hands $35 and the car fired right up but then died while driving 20minutes later. I have ordered a new distributor it is easy to replace but cost $275.00 will let you now if this works
