Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 05-21-2007, 08:37 PM
captainray34 captainray34 is offline
93 supreme keeps shutting off
I have a 1993 olds cutlass supreme that keeps shutting off when it gets hot. I took it to a mechanic and he thinks it is the shaft control sensor. He calls it the car from h ll. Does anyone know where this is located on the dual overhead cam 3.4? Thanks
Old 05-22-2007, 12:05 AM
3100MPFI 3100MPFI is offline
Send a message via AIM to 3100MPFI Send a message via MSN to 3100MPFI
Re: 93 supreme keeps shutting off
If that is the CRANKSHAFT position sensor, it is located on the rear of the engine under the exhaust manifold. It is right in the middle.
Old 05-22-2007, 01:54 PM
Thanks for the reply. Is it hard to reach? Can I get it with the car in the driveway. Thanks for al the help. The mechanic is telling me the car is done. I have 205,000 miles on it and changed the oil and filter every 5,000. I hate to junk it over a sensor.
Old 05-22-2007, 06:01 PM
well.....
The overhead cam is harder to get too than the pushrod. But it is NOT impossible. the thing I would be more worried about is if it BREAKS when you are trying to remove it.
The best thing to so is to see if you can feel around for it. Just get on the PASSENGER SIDE, and try to get your arm down, and around the back. In the case of the DOHC, you might be able to get it from under the car. Just jack it up, support it, then try to get your arm between the alt, and tranny.
To be honest, I am rebuilding a twin cam for my 1995 Cutlass Supreme, and I think I would rather just pull the engine to do it.
Kinda hard to see, but on my 1995 twin cam, there are 2 sensors on the back. I circled the CPS. the other one on the right (looking at pic), is the KNOCK sensor.
Old 05-22-2007, 09:04 PM
found another picture. Sorry so grainy.
Old 05-24-2007, 06:56 AM
Thanks for the reply, I will give it a shot by jacking it up.
Old 02-05-2015, 05:35 PM
jinxyzboi jinxyzboi is offline
Check the vacuum line to the MAP sensor and make sure there is no raw fuel in it. If there is then the diaphragm in the fuel pressure regulator is broken. This is a shared vacuum between the both. If that diaphragm is broken the car will run like a dog with two broke legs till its replaced. It's an easy check!
