Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 05-29-2007, 02:12 AM
Bryan22 Bryan22 is offline
1998 STS 3rd Taillight
The third taillight on the the top of the trunk lid is not working. Is there any problem that is common with these. We bought the car a couple months ago and I didn't notice this right away. Your help is appreciated.
Thanks,
Bryan
1998 STS
1997 Park Avenue
1997 GMC Sub
1993 GMC P/U
1971 Datsun 240Z
Old 05-29-2007, 06:02 AM
caddydaddy caddydaddy is offline
Re: 1998 STS 3rd Taillight
The only solution is a replacement. Here's some info:
"1998-2004 Cadillac Seville STS LED brake light
Currently unavailable. All 1998 to mid 2001 brake lights leak water. 100% failure. The only current fix is to replace the lamp with a mid 2001 or newer lamp. The mid 2001 and newer lamps use a better sealer. It should also be noted that this brake light is available under 2 different part numbers from Cadillac. It is available alone, or with a unpainted lower trunk close out panel. The current GM replacement part #25697411."
Try www.gmpartsdirect.com or www.gmotors.com for a replacement. You can find used ones on eBay, but I'd be sure they were off a 2001 or newer Seville.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
