Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-22-2007, 02:46 PM
theodorep theodorep is offline
Question 91 Olds runs great but don't turn it off
Folks, I have 1 91 Olds Cutless Ciera with 3.3, auto, 250K, AC. The car runs great, starts fine, good performance. If I run it for 8 hours it will run problem free. However, if I turn it off, and try to restart it, it will, but it will run very rough, the check engine light comes on and it will stall. If I wait for about 2 hours or more, it will start fine, run great, and no Check Engine.
The codes I pulled today were 42 and 44. Appreciate the help.
Old 04-22-2007, 07:26 PM
maxwedge maxwedge is offline
A990 racer
Re: 91 Olds runs great but don't turn it off
Have the ign. module tested for starters, it may pass though as your condition is heat related and the test may show good.
Old 04-23-2007, 04:33 PM
JohnDD JohnDD is offline
Code 42 is Electronic Spark Timing (EST) Circuit. Could be poor connections in cct 423 (white) or circuit 424 (tan/blk) wires between ECM and Ignition Module.
Code 44 is Oxygen Sensor Cirucuit (Lean Exhaust Indicated).
