Cars broke
Well my car just broke down on me. Got a big radiator leak somewhere, can't find where it is, because all the anitfreeze hits the fan and flys everywhere. Also while I'm driving my car starts backfiring and usually dies on me, it will only keep running if i slam on the gas pedal and hold it there for awhile. can anyone think of what the problem could be?
gonna be sitting at my house for a while, till tuesday or wednesday, then going to be hauled down to my dads to hopefully be fixed soon.
Tony 91 Civic Sedan DX - Stock 287k Miles |
is coolant still getting thru the engine?
2002 Acura TL Type S 1991 Honda Crx Si |
get a new radiator. second sounds like your not getting the fuel you need because you gotta keep adding fuel to keep it going. maybe try fuel injection cleaner and a new fuel filter. keep us posted on your car after you try this stuff.
Well the radiator didn't start leaking till yesterday after I was adjusting my clutch. Thought I might have knocked a hose off. I will see if my dads shop can find out what is wrong with it, then I'll probably fix it.
I'm thinking its probably my fuel filter is the problem with the car dying, cause it should be the fuel injectors cause I usually keep injector cleaner in it all the time. Hopefully it shouldn't be anything major and able to fix it in a day or so.
you better fix that radiator QUICK!!!
no coolant in your engine makes it heat up and aluminum heads are WELLKNOWN to crack and warp under heat. |
Yea, my collant hose cracked and sprayed coolant everywhere on my engine bay and i fixed it quick when i found it and thank god i diddnt crack my block! I am not ready for my engine swap just yet
88 DX Hatch SOLD! 90 Si Hatch Wreck'd :Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!! 96 Saturn SL2: Daily Driver untill 91DX is running! 91 DX Hatch: Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!! ![]() Official 4th Gen OG Hype Race Crew |
sounds like that is the problem with mine, just going to get someone to look at it to make sure. Not driving it any until it gets fixed, just been riding my skateboard to work and I got a friend that goes to the same classes as me, so don't have a problem there either.
You can see the spray on the inside of the hood
AF Bay Area Crew ![]() 97 Toyota T100 xcab 3.4l v6 5spd 2wd |
Hey, maybe have the fuel filter checked out.
Alright, well found out what is wrong with my radiator, gotta leak on one of the brackets for the little plastic tube from the stock intake, its about 1" to 1 1/2" long. Bout to put some quik steel on it and hopefully take it to a salvage yard and get a new radiator.
I'm also about to get a new fuel filter to put on it, just gotta find a ride to the store. Only 1 of my friends has a vehicle that runs right now. Kinda sucks.
You might want to check inside the distributor cap to see if it got wet from the leak in the radiator.
Sometimes electrical problems can "appear" to be fuel related. Just a thought!!! |
I was thinking something along that line. Didn't think my fuel filter just happened to go out at the same time as the radiator leak. Gonna check that before I spend 150 bucks on a new fuel filter.
Wisdom!!!
