![]() Join Date: Nov 2005
Check Engine Light.... Regular Gas?
Hello,
Recently my started wife driving the old 1998 740il when the check engine light came on. She said that the last time she filled the car up she used Regular gasoline and shortly after the engine light came on. I checked all the standard stuff like the gas cap but the light still remains on. I was wondering if putting in Regular unleaded gas might cause this issue. Any help would be appreciated. Thanks. |
Re: Check Engine Light.... Regular Gas?
Not really sure but ive been told that it could, my manuel says nothing less than 89 octaine, but the service dept said I should use high test. my 740il is a 97 and ii in the usa.
This happend to Marz740il...except when he got his OBD port scanned, it came back with fuel trim malfuntion and he filled up with 89.
http://www.automotiveforums.com/vbul...d.php?t=681184 I'm curious to know what your error codes are if you've scanned them yet...
1990 E32 750iL --> Pictures Production: 02/1990 Johan and Sean's E32 Page - Repairs and How-to's E38.org - Information and tech tips for BMW's Shogun's E32 Tech-Tips Gale's Repair Page ETK Online |
here are the codes ive gotten.
p0150:02 sensor circut, bank2-sensor1 malfunction P0136:02 sensor circut, bank1-sensor2 malfunction P0156:02 sensor circut, bank2-sensor2 malfunction P0173:Fuel trim, Bank2 malfunction P0308: Cylinder 8 Misfire detected P0130:02 sensor circut, bank1-sensor1 malfucntion P0100: not sure? |
Test O2 sensor on Bank 2 before the cat. Replace if nessesary. Sensor 2 is after the cat (I think). P0136:02 sensor circut, bank1-sensor2 malfunction As above. Only on Bank one after the cat. P0156:02 sensor circut, bank2-sensor2 malfunction As above...again, except on bank 2 after the cat. P0173:Fuel trim, Bank2 malfunction Vacuum leak on bank 2. Might be MAF sensor as well. P0308: Cylinder 8 Misfire detected Check spark plug, ignition leads, distributor caps and distributor rotor. If those check out fine, post back here. P0130:02 sensor circut, bank1-sensor1 malfucntion As above except on bank 1 before the cat. P0100: not sure? P0100 115 Mass or Volume Air Flow Circuit. Make sure the contacts are clean and making contact. It is possible that the connector to the MAF has wriggled loose a bit. If that checks out fine, test the MAF circuits with a volt meter. I can't remember the pin outs or the voltage readings for each pin, I will try to find these. Once you check those and if they read fine, clean the MAF. If cleaning makes no difference, you might be looking at replacing a MAF.
