Old 03-06-2007, 11:28 AM
Amechanic's Avatar
Amechanic Amechanic is offline
97 no hot air
Hi all,
My 97' Cherokee gives no hot air (just warm air). All related parts were inspected and replaced, such as radiator cap, thermostat, coolant. Any advices are appreciated.
Old 03-06-2007, 01:00 PM
Stick89's Avatar
Stick89 Stick89 is offline
Send a message via Yahoo to Stick89
Re: 97 no hot air
Did you back flush before putting the coolant in....
IF you have a vacum system check to make sure ALL vacum hoses are in the proper place and none are broken.
WOULDN'T IT BE NICE..IF WHEN WE SCREWED UP..TO JUST HIT..CLT...ALT..AND START ALL OVER AGAIN
Old 03-06-2007, 01:30 PM
masapell's Avatar
masapell masapell is offline
Re: 97 no hot air
Originally Posted by Amechanic
Hi all,
Just a suggestion here, but I would check to see if yours has a diverter valve. I am not sure if there is one on the 97, but I have one on a 96. It is near the firewall on the passenger side and connected to the heater hoses. There is a vacuum line going into it. The original one that I had desintegrated when I moved it to gain access to the rear spark plugs.
2014 Ram 1500 Crew Cab
Old 03-06-2007, 05:18 PM
1996Chreokee 1996Chreokee is offline
Re: 97 no hot air
are all of your hoses similiar in temp? or do you have one that colder or much cooler to the touch (especially the heater hoses)
Old 03-07-2007, 12:12 PM
chrisl757 chrisl757 is offline
Re: 97 no hot air
I had the same problem with mine, and there wasn't a thermostat installed. Because of that, the valve was open the whole time and my coolant never reached 190+ because it is COLD here.
I went to "replace" the thermostat and lo and behold, there wasn't one. As soon as I put in a new one, VOILA, I had heat.
but if you already are positive that it got put in there, then don't worry about it.
