Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 02-19-2007, 05:00 PM
manlystanley manlystanley is offline
Just curious
Hello Everyone,
Every time I start my 2000 Ranger (manual transmission, V4), I hear two very load "relay like clicks". Does anyone know what these things are? I figure that if my ranger doesn't start sometime and I don't hear those clicks it would help me deduce what is wrong.
Thanks for the help.
Best Regards,
Stan
1995 Plymoth Grand Voyager; 1998 Volvo S90, 2000 Ford Ranger, 2002 Dodge Grand Caravan.
Old 02-19-2007, 05:13 PM
DonSor DonSor is offline
Re: Just curious
I think your engine is I-4. Nonetheless, sounds like you got problems with the starter solenoid.
Old 02-19-2007, 09:43 PM
Re: Just curious
DonSor,
Your correct about the I-4. Its my first inline and I keep forgetting that its not a V
About the loud clicks, does nayone else have them? If not, then maybe something is going bad.
Best Regards,
Stan
Old 03-08-2007, 09:50 PM
98XLTKid 98XLTKid is offline
Re: Just curious
i may have the same sound, it only happens for me on cold days right after i start the truck and lasts for about 2-3 seconds, but im sorry to say i don't know the cause
Old 03-09-2007, 09:44 PM
Re: Just curious
Now that its starting to warm up here, I have not heard the clicking sound as well. It did sound like some big relays for 2-3 seconds. Thanks for the post and confirmation.
Best Regards,
Stan
Old 03-10-2007, 12:28 PM
Re: Just curious
Your solenoid contact maybe badly pitted. That could cause high resistance and also could cause it to momentarily "fuse" during start. I would advise you to correct the problem now cause it may cause additional more serious damage to your starter system.
Old 03-11-2007, 07:44 PM
Re: Just curious
Donsor,
Will do. In my Haynes book, it does not have a part in the starter system called a solenoid. However, it does have a "starter relay", that's located between the battery and the power distribution box. Is that what your talking about??
Thanks again,
Stan
Old 03-12-2007, 12:29 AM
Re: Just curious
Some call it "solenoid", others "starter relay". They're the same. It's called solenoid because there is a coil that when energized (by your ignition switch) actuates a plunger that closes a set of contacts and engages a gear which allows the starter motor to turn your engine.
Old 03-12-2007, 01:03 PM
Re: Just curious
Donsor,
Thanks. I'll pick up the part on the way home.
Best Regards,
Stan
