I just bought a used 2000 Passport. One month later I have a major problem. In the morning car starts great, but when I drive 15 miles to work and try to start 9 hours later, car sometimes takes 3-20 times to start. It will try to start, but just won't turn over. When it finally starts, it can be restarted over and over without problems. It is intermittent, so doesn't happen every day. Car sounds and runs great afterwards, until the next day or so when it happens all over again. When trying to start, it doesn't smell flooded or anything. It cranks fine, just won't start.
It's been to the Honda dealer twice, but they tell me since they can't reproduce it there, then there's nothing they can do. I'm afraid to drive now since I don't want to get stuck. It's definitely not the battery (will try to start and besides, it's brand new and was checked by dealer), and just passed the 45,000 mile inspection at the dealer with flying colors. Anyone have any suggestions? I don't want to just blindly replace parts unless I know for sure they are bad. The dealer is charging me a small fortune! |
Re: 2000 Passport has intermittent hard start
It it either the intake manafold gasket or the fuel pressor regulator.
http://www.geocities.com/endre_rl/isuzufaq.htm#faq22
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
you say it will try to start. does it turn over or just click
When trying to start, it doesn't just click, it actually sounds like it's going to start, but just doesn't actually turn over. I guess it's not getting any fuel since it never smells like it's flooding. It seems to only happen after it's been driven at least 10 miles and sits for about 8-10 hours. It's so inconsistent with no pattern. I can let it sit overnight after driving 10 miles and it starts right up. It happens more often when it's only sat for 8-10 hours, then when it has sat overnight. It's the strangest thing since it runs so great once it starts and can be restarted as many times as possible without a hitch. All I know is the problem is getting worse as it's taking longer and longer to turn over, yet it starts right up each time it's at the dealer.
Update: Just got off the phone with the dealer. I asked them about the intake manifold gasket and the fuel pressure regulator. The mechanic said most likely it wasn't the intake manifold gasket and since they can't get it to fail, they don't know for sure what the problem is. They recommended first replacing the relay and if that doesn't fix it then return it and they will replace the fuel pressure regulator. I hate replacing parts which I don't know are truly bad or not, but as far as I'm concerned, the car is undriveable at this point. I guess I have no choice, so I'll go with the cheapest repair first. I suspect the last owner got rid of the car because he/she was experiencing this same problem. Last edited by Mowzer; 11-03-2004 at 12:17 PM. |
There's a bit of confusion with your terminology Mowzer (no biggie
).. So the starter is actually engaging & cranking/spinning the engine over right? The engine just wont fire up. Have you tried mashing the gas pedal while cranking the engine to see if that makes a difference? Are you getting a check engine light at any time? This *sounds* like a fuel delivery concern (fuel pump, or fuel press regulator not allowing the fuel rail to pressurize) , but needs more troubleshooting to be sure . Keep posting any symptoms/concerns & maybe we can get to the bottom of this!!G/luck Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
Sorry, I'm probably not using the best terminology to describe the symptoms since cars are certainly not my forte. Yes, the starter is actually engaging, yet the engine won't fire up. Yes, I've tried mashing the gas pedal, but makes no difference. The check engine light has never come on.
The Honda dealer says they can just keep replacing parts, but as you know, this begins to be quite expensive. He first recommended replacing the relay since it is only a $8 part. If that doesn't work, then the next step will be the Fuel Pressure Regulator. If I'm still having problems, then probably next would be the actual Fuel Pump. Of course by this time, I will have probably invested more money than if I had bought a much newer vehicle :-). Thanks everyone for all your help! I really appreciate the advice. I'll keep you posted. Last edited by Mowzer; 11-04-2004 at 01:12 PM. |
mashing the gas pedal will prevent injectors from activating while cranking try this before starting it turn key on for 5 seconds turn it off for five and then try starting it. Oh and has the fuel sending unit or fuel pump been replaced recently
I had a very similar problem with my Rodeo 99. I brought it into the dealer numberous times. My check engine light was never on. The dealer was never able to tell me what was going on. About two weeks later, it just quit starting. I had to have it towed to the shop. I brought it to an independent place, as opposed to the dealer, because I was so fursterated at the dealer for not fixing it when I had it in and now having to pay for a towing.
This place diagnosed it almost right away. It was the crank shaft position sensor. They replaced it and did the timing belt while they were in there. I haven't had a starting problem in over a year. I hope this helps! |
Unfortunately since I bought the vehicle used only a couple of months ago, I don't know anything about it's past history except it was a lease return which eventually was sold at auction. It ended up at a used car lot where I purchased it for it's rather low mileage for an older vehicle.
It's currently at the dealer waiting for the new relay to arrive. I also left a message asking them about the crank shaft position sensor. I too am frustrated with the dealer as he basically told me that I need to wait for the car to fail completely before they could diagnose it. Of course for me, that would mean I would be stuck out in the middle of no where at night and have to be towed 40 miles with no way to get home. Thanks again. Any advice is greatly appreciated and I'll try anything at this point. I'll keep you posted. |
I had a similar problem with a previous vehicle only trouble starting, but once it was running there was no problem. I found that it was the relay that controls the fuel pump. Very inexpensive item and easy to replace. Sounds like you are on the right track changing the relay first.
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k |
Well relay was replaced, but now problem seems almost worse then it was before. The problem is almost repeatable each time now when it has been driven for at least 10 miles, then sits for at least 10 hours.
Dealer was no help as they will not drive it for 10 miles, then let it sit to reproduce the problem. They claimed they did, but odometer proved they really didn't. I've been told that the only way they can diagnose the problem is to let it fail completely, then have it towed. To me, this is an unacceptable response as I want it fixed before I'm stuck in the middle of nowhere. My next step will be to bring it to another mechanic (non-dealer) and see if they can determine if the problem is with the fuel pressure regulator or something else. One odd thing which may only be a coincidence. I seem to get it to start faster if I try from neutral (it's an automatic). It will only take 2-3 attempts rather than 5-10 attempts from park. |
You figure this out yet?
No :-(. The mechanic I brought it to hasn't had a chance to look at it yet in the two days it's been sitting there. From the dealer's point of view, there's nothing more they can do for me until the part fails completely. I can continue replacing parts without knowing definitely if they are bad, but the costs are too high. To replace the Fuel Pressure Regulator, I've been quoted approximately $300. For the Fuel Pump itself, approximately $700, for the crank shaft position sensor, over $1000. Since the parts are probably still covered under my extended warranty, I can't claim unless I can prove the part is truly bad. And I can't do this, until it completely fails. It's been a very frustrating experience so far! I'll provide an update once this new mechanic has actually looked at it.
Update: Bad news for me. This new mechanic also told me to come pick up the car as there is nothing they can do for me until the part fails. Therefore my only option is to wait until I'm stuck. :-(. |
It just keeps getting worse. I asked the mechanic to quote me what he would charge to replace the Fuel Pressure Regulator. He called back and told me that the part was so back ordered, that he couldn't even be put on a wait list. He said this is an indication that this particular part failed often. He suggested if I wanted this part replaced, then I would have to try to locate the part myself.
st charles will help you out.
the part costs 54 bucks and will take about an hour to replace.
