Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-19-2007, 09:38 AM
jteam jteam is offline
1994 Rodeo with surging idle, tried everything
I am nearly at my wits end with this thing! I am a former Chry/Dodg/Plym tech (changed careers), and an avid DIY'er when it comes to my vehicles.
I have a 1994 Rodeo 2wd, with 3.2L V6 w/ 5 speed. I bought it off my Dad nearly ten years ago, who bought it new, and it has served us well. Now that I want to get rid of it, it has played havoc on me (feeling betrayed maybe? lol).
It has in intermittent problem. Sometimes it revs up to 2000-2500 rpms and back down below idle, up and down, up and down. Sometimes its just a few times and returns to normal. Sometimes it continues regardless of how far you drive it. sometimes it revs up and just stays up there. Other times it runs perfect. I have searched many forums and boards looking for an answer. I have even tried some suggestions from them out of frustration. I had a paid access to TSB's for this vehicle, but can no longer find the discs for it, so I am out of luck on that. Any help would be appreciated.
The following things have been done, some were needed, some were shots in the dark and some were "just because I was in there".
Intake manifold gaskets
Throttle body removed and cleaned 3 times
IAC removed, cleaned as well as IAC port, more than once
EGR valve and tube removed and cleaned
all vacuum hoses replaced
Plugs and wires
swappped out Coil pack and ignition module with used one
swapped out IAC valve with used, (cause carb spray will mess one up! Trust me)
PCV valve, hose, and grommet replaced
CTS replaced (when IM was off and its a B*&^h to get to)
all located grounds under hood were removed, cleaned, repaired etc.
tested crank sensor per Haynes Manual
Tested TPS per Haynes Manual
Tested Charging Sysytem per Haynes Manual
visual inspection of PCM connectors
tested Power steering pump switch per Haynes
And no trouble codes!
I am sure I am forgetting something that I have completed.
Any expertise would be greatly appreciated. What am I missing. Anyone with TSB's or manual pages they could send me? Any Isuzu/Honda Techs out there? Anyone have the same problem and actually narrow down what solved it? (or are we all just driving around bucking like we are going for the whole 8 seconds? )
I am nearly ready to try anything reasonable.
Old 02-19-2007, 10:10 AM
Cat Fuzz Cat Fuzz is offline
Re: 1994 Rodeo with surging idle, tried everything
Ok. I'm going to throw this out there just because it popped into my head. I've never experienced this before but it seems like it could cause, what seems to be, and intermittent vacuum leak.
What about the charcoal canister and purge solenoid system? It seems to me that this only operates at certain times to purge the canister of fuel vapors. What if, when the canister is being purged, there is a vacuum leak at the solenoid or the canister itself?
Like I said, just throwing that out there.
