Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 02-11-2007, 07:03 PM   #1
93hoopty
gas in oil
93 s10 blazer 4.3 w auto. 175,000 miles. code 32 stalling and now no start. Replaced egr, map sensor and found small amout of gas in oil that slipped past cylinder 3 & 6. Have no fuel pressure tester. Out of experience would you say spyder assembly, injectors, or fpr? or what else?
93hoopty is offline   Reply With Quote
Old 02-12-2007, 06:21 PM   #2
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
Re: gas in oil
if its the 4.3 vortec VIN W then id say you have a leaking CPI/regulator or nut kit. remove the upper intake to check for washed areas.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
ZL1power69 is offline   Reply With Quote
Old 02-19-2007, 07:59 AM   #3
tg5398
Re: gas in oil
I didn't think they put the vortec on until '94.
tg5398 is offline   Reply With Quote
Old 02-19-2007, 10:28 AM   #4
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
Re: gas in oil
correct, the 4.3 CPI was not introduced in the s10 till 94, but we are talking about a s10 BLAZER which had the 4.3 CPI in 93 (i believe on LT models).
anyway, there are a couple ways to determine if you have a leaking CPI or nut kit. you could pull the vac line off the brake booster and take a wif and see if you can smell gas, you could remove the IMTV from the top of the intake (under the plastic vortec cover) and look down inside the manifold for leaks, or you can remove the upper intake. the inside on the intake should is usually a grimmy black color. if the passenger side of the manifold is clean, your regulator is leaking. if the drivers side is clean, then the nut kit is leaking. if you take the upper manifold off, turn the key on to pressurize the system and look for leaks. also, if you have a leak, fuel pressure will drop off fairly quickly after the engine is shut off.
Low 11 sec sleeper
My Cardomain
