Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-14-2007, 01:14 AM
StreetLaw's Avatar
StreetLaw StreetLaw is offline
Send a message via AIM to StreetLaw
16g Turbo Questions
I have a 92 Talon TSi AWD. I'm currently in the market for a 16g. Does anyone know which 16g is best and what is a 16g turbo psi range?
Thanks!
Mike
Old 02-14-2007, 02:46 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: 16g Turbo Questions
Well here is a good page that goes through all the differances between them.
http://www.roadraceengineering.com/eclturbos.htm
In my opinion the MHI EVO III 16G is the best, but it really depends on what your horsepower goals are.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 02-14-2007, 03:18 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
EvoIII 16G is the best bang for your buck, or best "potential" for your buck in your case. It's a sweet turbo, and isn't much more than the other 16g's (if you buy all new).
95 Talon TSI AWD
97 Eclipse GST
Old 02-14-2007, 09:57 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Just dont get an eBay Evo III 16g and you should be fine. Get it from a reputable shop and you will be good.
I guess I too would say get an MHI Evo III 16g. As far as boost pressure goes, it all depends on your setup. If you are on stock fuel system and intercooling, I wouldnt run more than like 12 pounds. Get an adaquate fuel system and some decent intercooling and like 18 psi should be a good street boost pressure.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-14-2007, 01:14 PM
StreetLaw's Avatar
so basically i would need at least 550cc injectors and 190lph fuel pump to see more then 12 psi?
Old 02-14-2007, 01:44 PM
Thor06's Avatar
Jizzed In My Pants
I would, yes. Dont forget fuel control and data logging. A turbo should be one of the last mods you do, otherwise you risk major problems. DSMlink is far superior to a SAFC + pocket logger combo, but the SAFC + pocketlogger is cheaper. One of those, a 190, and 650cc injectors (just to be safe) is what I would do for running a 16g. Also, a 3" exhaust, boost guage, and a boost controller are things you should do before you worry about slapping a turbo on. Where not entirely needed, a FMIC is another thing I would recommend before you do the work of tuning the car with the 16g.
Old 02-14-2007, 03:39 PM
StreetLaw's Avatar
ok i will work on those things thanks for the help i greatly appreciate it
1992 Eagle Talon TSi AWD
