Go Back   Automotive Forums Car Chat > Mitsubishi > 3000GT/Stealth
Old 01-26-2007, 05:37 PM
X2Xtreme360 X2Xtreme360 is offline
clutch fluid leak
Well after browsing the manual, I'm a bit confused. They kinda put the AWD and FWD removal steps all in the same picture, so I get a bit confused seeing everything in one photo. I have a leak. I see it under the driver side front tire, so that rules out the possibility of it being the slave cylinder (also called the clutch release cylinder in the manual?). So my only two options would either be the master cylinder or the actual line, right?
Once again, the manual is a bit fuzzy in some places, especially the instructions on bleeding the clutch. It basically says "you should bleed the clutch sometimes." Is the bleeder screw on the slave cylinder near the transmission?
Old 01-26-2007, 05:56 PM
2old 2old is offline
Re: clutch fluid leak
http://www.stealth316.com/2-clutchbleeding.htm
Old 01-26-2007, 09:15 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
bleeder screw is on the slave cylinder, on top of the transmission. i've never heard of ppl seeing clutch fluid under the tire, but if its in that region, it could only be the master cylinder. the hard line on that side of the car is all metal, and doesn't leak.
to double check to see if its the master, you can check with a flashlight around the clutch master cylinder reservoir. also, look under the dash around the firewall. there is a rod that goes through the firewall (from the clutch pedal) surrounded by a rubber boot. this is the place from which the clutch master will usually leak. you might also see fluid down onto the carpet.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-27-2007, 12:20 AM
well after looking around where the master is, i notice it's very wet, even on the cap. I filled it up but I know I didn't miss my target. I guess my plan is to empty the system, take out the master and examine it the best I can. That's gotta be my problem.
What puzzles me is how I have no pressure whatsover. So little that in order to get home this morning I couldn't use the clutch at all. That rod you were talking about, is it the rod on the right with the golden wishbone type end on it?
Are you talking about that black boot at the beginning of the rod?
After refilling the reservoir, the level really doesn't go down that much. Maybe too much air has already entered the system? I dunno I can't think of a reason for it to act like this. Anyway, I'm gonna bleed it dry within the next couple of days.
I do need to know how to remove the master cylinder. Is it held to the chassis or firewall?
Old 01-28-2007, 12:35 AM
Linebckr49's Avatar
yup, that's the rod and boot i'm talking about.
don't bleed the system dry. if, indeed, air has entered the system, then you don't want anymore air to enter. so as you are bleeding the clutch, make sure that there is always at least some fluid in the clutch fluid reservoir (master cylinder). if at any time all the fluid goes from the master cylinder down the line, then air will enter the system.
so you did see some fluid leaking from the rubber boot under the dash?
93 3000GT base
Old 01-28-2007, 12:44 AM
Absolutely did. Thanks for the tip off. That's exactly where it's coming from. I'm releived that it's only the master cylinder. I might upgrade the stock rubber hose (the one going to the slave) to the steel braided hoses on 3sx while I'm at it. I'm stuck as of right now since I don't have a master cylinder just laying around, I'll have to order one. I might gut my precats if I have time, since my cars just sitting in the garage for a few days.
Old 01-28-2007, 04:35 AM
Linebckr49's Avatar
you could also eliminate the clutch damper. it will make future clutch bleeding much easier and faster. and it will clean up the cluttered engine bay. i did a write-up on the clutch damper delete here.
oh, and i got the AC tensioner pulley shipped out wednesday morning. i was out of town and didn't have computer access to let you know. its supposed to arrive tuesday. i'll include more details in a PM.
93 3000GT base
Old 01-28-2007, 04:13 PM
Thanks, I wasn't sure if you got my message.
I think I might remove that damper. But I shouldn't bleed the system dry? Would this hurt the system even though I'm just gonna fill it back up agaiin?
I also read that you had to remove the brake master cylinder to remove the clutch master cylinder, is this true?
Old 01-28-2007, 06:32 PM
Linebckr49's Avatar
tell me how and why you plan to bleed the system DRY.
you don't want air in the system, logically, you don't want to bleed the system dry. if ur worried about getting old fluid out and new fluid in, its simple. add new fluid, bleed system until all dirty fluid is out (that is, bleed until only new clean fluid comes out the other end).
about replacing the clutch master cylinder, i found on 3Si that some people were able to do this WITHOUT removing the brake master. i'll do some searching, to find more details. it was a bit tricky, but if you can do it WITHOUT removing the brake master, it makes the entire process about 10x quicker, b/c then you won't have to bleed the brakes at each of the 4 wheels.
93 3000GT base
Old 01-28-2007, 06:47 PM
Linebckr49's Avatar
here's how to remove the clutch master cylinder WITHOUT removing the brake master http://www.3si.org/forum/showthread....=clutch+master. however, i will tell you that in most cases, those fluid hard line connectors have been on there for the life of the car. and so they will be VERY difficult to get loose. on mine, i've stripped every single one using a 10mm wrench. the only way i found to NOT strip the connector is to use some vise grip pliers. however, there's not enough room for any size vise grips (even the small ones), so i had to remove the brake master to access the clutch hard line with my vise grips.
if i were you, i would try to method mentioned in the linked thread first. try to use a crowfoot 10 mm wrench to remove the clutch hard line. if you strip it, then you'll have to just remove the brake master and use some vise grip pliers.
93 3000GT base
Old 01-28-2007, 09:02 PM
sLADe781 sLADe781 is offline
Here's one with pictures: http://www.3si.org/forum/showthread....er+replacement
I did mine without removing the brake master. Just take your time and be really careful down there. Without the crowfoot wrench, I don't know how I would have gotten down there so go buy a set. Sears = $50 or go to AutoZone and get a cheap set for about $15. Good luck.
Old 01-29-2007, 01:02 PM
They talk about rebuilding the master cylinder for 10 bucks as opposed to buying a new one. This would be ideal for me. Where can I get a rebuild kit and will this fix the leak where that rod is?
Old 01-29-2007, 02:00 PM
Linebckr49's Avatar
you can get a rebuild kit at your local chain auto parts store.
93 3000GT base
Old 01-29-2007, 11:56 PM
Well, after removing the reservoir plastic container, I moved on to remove the 10mm hardline bolt... It's still connected, lol. (Don't know why I'm laughing it kinda sucks) I sprayed a lot of PB on it and I'm gonna let it sit overnight to see if it helps. I think I can rule out pliers and wrenches because I'm in fear of stripping the bolt. I guess I'll see how everything goes in a couple days.
Old 01-30-2007, 12:33 AM
Linebckr49's Avatar
i told you that bolt was gonna be a PITA. a wrench will surely strip that bolt. however, some vise grip pliers won't. with the vise grips, you can make the opening small enough so that when you grab the bolt, the pliers will be on there VERY tightly. so then, when you go to break the bolt loose, it will not strip it b/c its held on so tight. on the other hand, if you were to use a wrench, since its not held on tightly, it will surely strip the bolt if the bolt is rusted in there (most likely it is b/c it has never been loosened in the life of your car).
93 3000GT base
