Go Back   Automotive Forums .com Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 04-11-2007, 10:57 PM   #1
06chill
06chill's Avatar
06 ser mods?
just wondering if anyone has an 05-06 ser spec v with mods and what they have noticed worked well and what didnt cuz im looking into getting some and want some info
06chill is offline   Reply With Quote
Old 04-12-2007, 03:57 AM   #2
nismo_pilot
Send a message via AIM to nismo_pilot
Re: 06 ser mods?
a cold air intake is your first stop and right after that is motor mount inserts, then header and balance shaft removal, all very effective
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
nismo_pilot is offline   Reply With Quote
Old 04-12-2007, 10:23 AM   #3
06chill
06chill's Avatar
Re: 06 ser mods?
so you have felt the best gains out of these mods. cuz im looking at a throttle spacer to start the car is still new so im trying to not go crazy with it yet
Old 04-12-2007, 01:54 PM   #4
nismo_pilot
Re: 06 ser mods?
people have had problems with how their car runs with a throttle body spacer, plus its best used after you already have mods, the ones i listed give the best gains
Old 04-12-2007, 06:34 PM   #5
slideways...
slideways...'s Avatar
Re: 06 ser mods?
you can use headers and cams also, both of those will give you some nice gains. just get street cams. race cams will get you more top end but wont be worth it because of the drop in useable hp and torque. plus with some stage 1 cams you dont have to replace the valvesprings and retainers.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
slideways... is offline   Reply With Quote
Old 04-13-2007, 12:31 AM   #6
06chill
06chill's Avatar
Re: 06 ser mods?
ok so what are you talking about with the balance shaft if you dont mind me asking
Old 04-13-2007, 06:33 PM   #7
slideways...
Re: 06 ser mods?
theres a balance shaft assembly that sits in the oil pan, basically a set of counterweighted gears that spins opposite the direction of the crank, to compensate for the imbalance of a 4 cylinder engine with a huge stroke. not only does it suck power by running off the crank, its spinning gears in the oil pan froths the shit out of your oil, potentially leading to some nasty oil pressure related issues.
jim wolf tech has a removal kit that replaces it with a baffle in the pan. the only downside to removing the assembly is increased vibration, which ive heard is no worse than having stiff motor mounts.
ive heard it suggested that you will gain 5-8 whp with the balance shafts removed. ive also heard that its probably a good idea to ziptie all loose wiring in your engine to prevent harness failure due to the extra vibration.
Old 04-17-2007, 09:56 PM   #8
06chill
06chill's Avatar
Re: 06 ser mods?
i think im going to get a cold air intake first im looking at the aem one cuz i dont want some off the wall brand. also i was wondering were you get your mesh grille inserts or what cuz i dont like the big nissan symbol in the front i think it looks tacky
Old 04-18-2007, 12:23 AM   #9
06chill
06chill's Avatar
Re: 06 ser mods?
and i was also wondering if you knew of a way to increase the rpms like a good chip company or something.....
Old 04-18-2007, 04:20 AM   #10
fugiot
fugiot's Avatar
Send a message via MSN to fugiot
Re: 06 ser mods?
We're still waiting for the JWT chip...
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
fugiot is offline   Reply With Quote
Old 04-18-2007, 10:45 AM   #11
nismo_pilot
Re: 06 ser mods?
technosquare reflashes spec ecu's but it costs like 600 bucks or something for a 1000 rpm increase but you need new valve springs rated to 7500 rpm, also its useless without the jwt cams to use the extra redline, its like a 1500 dollar upgrade to do it right
Old 04-20-2007, 10:53 AM   #12
slideways...
Re: 06 ser mods?
increasing redline in a spec is very very risky. the valve springs arent what need fixing, its the huge stroke and horrible rod ratio. unfortunately theres not much you can do to fix this. there are a few companies that have toyed with the qr as a race engine, and found that increasing the redline to 7000 brings piston speeds higher than an F1 car. think about that for a sec. F1 cars spin to over 15,000 rpm... instead, do what you can to make as much power under the stock redline.
Old 04-20-2007, 11:47 AM   #13
nismo_pilot
Re: 06 ser mods?
exactly
Old 04-22-2007, 11:48 PM   #14
06chill
06chill's Avatar
Re: 06 ser mods?
does anyone know how thick the sway bars on the 06 ser spec v are
