Go Back   Automotive Forums Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 01-24-2007, 11:31 AM
r0rr r0rr is offline
87 honda accord jumping tachometer & no power to fuel pump
I have an 87 honda accord. I was driving one day when I had a sudden loss of power and then a return to normal operation. Later that day, I noticed that the tachometer was jumping.
A few weeks later, the car died and would not start. It was not getting fuel. I checked the power line from the ignition coil to the fuel relay switch - no power. Per the recommendation of a mechanic, I replaced the ignition coil.
After replacing the coil, the car ran normally, but the tachometer continued to jump. Days later, the car died again - same symptoms.
If I supply power to the fuel pump, the car will start and run normally for a random length of time.
I have searched the internet for clues and I have found suggestions relating to the ignition module, the distributer, the alternator and the fuel pump. (one note of interest is that I replaced the alternator about 2 months before this problem occured).
Please help!
Old 01-24-2007, 01:58 PM
somick's Avatar
somick somick is offline
Re: 87 honda accord jumping tachometer & no power to fuel pump
It sounds like there is a bad ground somewhere.
I would also check the alternator. Should be 14.6 volts when running.
Good luck!
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
