I have a 01 Impala and saw two mesages on the Message Center and Ineed help How I can fix:
1.- Change Oil. I changed the oil and still the message appears. 2.- Low Tire pressure. - I fill the tires and they are in good pressure but still the message appears. Somebody can help me what happen ? Thanks. |
Re: Message Center Needs Help
You have to reset both the engine oil life monitor and the tire pressure monitor.
This is done with the radio -- hold down the DISP button for three secs, you'll hear a beep, and see "Settings" in the display. use SEEK to select the functions until you find the ones you're looking for, then SCAN to select RESET, hit DISP, and you will get a beep. I may have seek and scan reversed, but you can feel your way through the menus. |
If you don't have the factory-installed radio installed, you won't be able to reset it.... Unless there is some other way that I just don't know about... Just my
Thanks for the help This works!!
