Go Back   Automotive Forums Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 09-03-2005, 02:07 PM
lvpj lvpj is offline
Unhappy My 1999 Honda stalls while driving! Nobody can fix! HELP!
Hello,
I have a 1999 Honda Accord LX coupe. For over a year now, I have been experiencing the following problems.
1. Initially, it started out that if I would drive the car for a little while then shut it off to do a small errand (i.e. grab the mail), it would not restart for about 10-15 minutes. I would hear an extended cranking type noise. It began as very intermittent.
2. My car then progressed to stalling on me when I was either stopped at a red light or slowing down to take a turn.
3. NOW, my car regularly stalls in the middle of the road WHILE I AM DRIVING! This is very scary!
I have had my car looked at like 8 times! The first 2 times at a Honda dealer, they told me they "could not duplicate" the problem. Then I took it to a non-dealer, who referred me back to the dealer b/c they couldn't figure it out. So I went to a different Honda dealer and they first replaced the ignition switch. That didn't work. Then they replaced the immobilizer system, and that didn't work. Then they told me I needed a whole new computer for my car and that would cost $1260. I declined further service b/c I didn't feel confident that this was the true problem. So then I brought it to ANOTHER non-dealer who then replaced the ignition module control and then a coil pack. NOTHING HAS WORKED! I don't know what else to do at this point! Can anyone tell me what this could be!?
There was a recall for some 1997-2000 Accords for the IGNITION SWITCH, but they told me that my car doesn't fall under that recall. I think I might have to trade her in because nobody can fix it ! Please help! Thank you!!!
Old 09-03-2005, 03:03 PM
mpumas mpumas is offline
Re: My 1999 Honda stalls while driving! Nobody can fix! HELP!
Sounds like they have looked at all the things I would expect to be the problem except the main relay. Because it is an intermittent problem, troubleshooting will probably come down to replacing all those items, one at a time, that could cause the problem. Start with the most likely ones then go to the cheap items. The ECU could be the cause but I would think you would get an ECU code. You might try a used ECU to see if the problem goes away. If that doesn 't fix the problem, you might be able to sell it back to the junkyard at a lower price then you paid.
Old 09-03-2005, 03:32 PM
Thank you. What is the ECU??
I don't believe that there are any codes coming up? Could the main relay not give off any code?
Old 09-03-2005, 03:52 PM
Igovert500's Avatar
Igovert500 Igovert500 is offline
blue + red light magnet
The ECU is hte car's computer. When you get a Check Engine light, your ECU stores a specific code that can be retreived and tell you what hte specific problem is.
As far as the main relay, if you are having a wire in that area intermittantly becoming loose, moist, or grounding out or something, that could be the problem.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Cusco front + rear strut bars
-Greddy type-s
-ATR downpipe
-no cats
-15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly.
Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical.
Old 09-03-2005, 03:59 PM
I am not getting any "Check Engine" light.
Is it possible that 1 thing is causing the car to not start and something else is causing the car to stall while driving? Meaning, could TWO things be wrong w/ my car, or does anyone think that ONE thing is causing both?
I know nothing about cars....
The dealer who told me it was the computer wrote on the invoice (after replacing the immobilizer ring and ignition switch):
"Replaced Immbolization Ring. Key Immob. Light will not come on - Intermitt rec om'd pcm. Customer aware and declined".
I have NO idea what any of that means.
Old 09-04-2005, 12:47 AM
timmytim timmytim is offline
Banned
Send a message via Yahoo to timmytim
The head of your key has a resistor in it and when you put in in the ignition, the Immoblization ring detects this resistance and allows you start the car. The ring wraps around the ignition switch right where you stick your key in. The rest of that is just mechanic talk.
I had an Accord with the EXACT same sysmptoms as yours. I had several mechanics look at it and no one knew anything. Then I met a man that saved my baby! He found that the little chip inside the distributor was burned out, and causing the intermittant stalling. I cant remember what the part is called but it controls your electronic timing. If I remember correctly, we had to replace the entire distibutor because the chip was soldered onto it. We got a used distributor from the junk yard, and it worked great for years! I dont know if this is your problem, but you really dont many more choices left, and ECU's are expensive, even at junk yards.
Old 09-12-2005, 09:08 PM
EZFrank EZFrank is offline
i had a diffrent kind of vehicle that was doing simular to yours and we replaced all kinds of parts and came to find out it was a ground wire make sure you check all you grounds and power wires especially at the distributor and alternator and starter. good luck. if you do find out what it is please let us know. thanks
[IMG]http://[/IMG]
Old 12-14-2005, 12:55 AM
supercoup8 supercoup8 is offline
Re: Re: My 1999 Honda stalls while driving! Nobody can fix! HELP!
Find the ECU. Sometimes when electrical parts get hot,they crap out. Start the car, and use a hair dryer to heat up the engine shuts down. Replace the ecu if it does. First check out the EGR valve. if it sticks open it will stall the engine.
Old 12-14-2005, 04:42 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
When it dies while driving, does it start back up right away, or does it have to sit or have extended cranking time before restarting?
If it's hard to restart, does giving it some gas pedal seem to help it?
Does it seem to die the instant you drop the gas pedal when it happens, or is there a period when it's idling fine and then it stalls?
...empty gun rack.
Old 12-14-2005, 04:49 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
at the moment the car doesnt start up again, thats the best time to check for fuel, spark, power, and cam timing. it will make your pinpointing of the problem much easier.
good luck.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-14-2005, 05:09 PM
russiankid russiankid is offline
Send a message via AIM to russiankid
try this, you may not get a engine check light but put the car in the ON position, pump the gas 5 times, and look at the check engine light, it will flash, it will flash how ever many times, count how many times it flashs, record the number, it will give you a sec or 2, then another time it will give you anther number, it will eventually stop and you will have a code, find what the code means by doing a search on google, so you can have a better guess on the problem
Old 12-17-2005, 11:38 AM
jgr7 jgr7 is offline
My brother has a civic that did the same thing he changed samething in the distributor that timmytim in post above mentioned.
Jeff
Old 12-17-2005, 05:11 PM
AccordCodger AccordCodger is offline
Guys, guys - supercoup8 woke this thread up - it's 3 months old. I doubt lvpj is still sitting there scratching his/her head, wondering what an ECU is.
Old 04-14-2006, 06:06 PM
Silentsnow Silentsnow is offline
Did anyone get this problem fixed? My car does the same thing now. I was stalling before and I changed the IAC valve and it went away but it did it again today after 5 months. Anyone have an idea why it won't start and it started to stall again let me know.
Old 04-17-2006, 01:44 AM
I got mine fixed it was the coil inside the distributor when it got hot it would not start or when you where driving sometimes just die at a light or stop sign hope you find the problem good luck
[IMG]http://[/IMG]
