Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 01-05-2007, 09:50 PM
MILVET MILVET is offline
Max Tire Size for 17' OEM Rim
I can't find the answer to my specific question. SO I'm posing it here.
I have a 2005 Silverado 1500 Crew 2WD LT. The current tire size is 245/70/17. I can't afford new tires From $400-$600+ and new rims. So, I just want to get the largest (Widest) tire that will fit my stock rims w/o rubbing. I was told by a mechanic that I should be able to get by with 265/70/17 maybe go up to 305/60/17. All thoughts are greatly appreciated. Thanks in Advance!
Old 01-05-2007, 09:58 PM
bigbadram51 bigbadram51 is offline
Re: Max Tire Size for 17' OEM Rim
You could probably get a 305 in there... I ran a 305/50 on 20" wheels (just barely rubbed on the inner fender well. Although im not sure of what the backspacing and offset is with a stock wheel. 285 would look good though.
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 01-11-2007, 10:43 AM
mr.23sgte mr.23sgte is offline
I have a 2000 z71. Will the 285 75 16 tires fit under my truck?? I have a stock set up.
Just figured I would keep it under the same thread. Thanks
Old 01-11-2007, 04:44 PM
99SilveradoRob 99SilveradoRob is offline
I have an 04 z71 stock suspension setup and I am running 285/75/R17 BFG A/Ts with no problem whatsoever.
