Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-18-2006, 10:39 PM
johnnore johnnore is offline
6.5L Diesel shooting out black smoke
I have a 95 6.5L diesel that is shooting out a lot of black smoke when you kick it down and does not go 75, would this be a injector problem, if so how would you diagnoise which ones it is and if not what are some other ideas
thanks
John
Old 10-18-2006, 10:49 PM
16th hippy 16th hippy is offline
Re: 6.5L Diesel shooting out black smoke
don't have alot of experience with the 6.5's, but i know they are notorious for pump problems. this is not the best news for anyone, but i hope others can help more with the diagnostics. you could always take it to a shop/chevy dealer and pay them the diag fee, and go from there. Either way, the black smoke is a sure sign of "over fueling"....either the pump is pushing too much, or the injectors are leaking...or regulator(i think it is internal on the pump) is blown.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 10-18-2006, 11:19 PM
chrisk1500 chrisk1500 is offline
Is this truck a turbo?
If so this will most likely have NOTHING to do with the IP or injectors....
DON"T LISTEN TO PEOPLE WHO START OFF BY SAYING THEY DON"T KNOW ANYTHING AND THEN START RATTLING OFF ABOUT HOW BAD THE IPs ARE!!!!!!
Scan your computer with a paperclip and see if you are getting a code 78....if so, check all of the vaccuum lines coming from the vaccuum pump up to the wastegate solenoid and from the solenoid to the actuator....
You will need to test for 15 inches of vaccuum on the line coming off of the solenoid....
94 Silverado 1500 Z71, 320 000 kms, 6.5 TD (VIN S), 3.73 rear, 4L80-E, high idle switch, snorkel removed, EGR blocked off with 45mm frost plug in tower, ISSPRO boost gauge and pyrometer (pre-turbo), #9 resistor, FSD cooler remote mounted behind bumper, 6' homemade PMD extension harness, 97 cooling upgrades, 10k pot set @ 10 psi boost, gutted upper intake, WAP glow plugs, leaf spring helpers....Saving up for: straight pipe 4" exhaust, intercooler, chip...
Old 10-19-2006, 11:59 AM
alblogg's Avatar
alblogg alblogg is offline
My old Dodge Cummins use to put out a lot of black smoke but man it went way over 75!
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-19-2006, 02:23 PM
Black smoke is wasted power......not a good thing......people who know what they are doing with a diesel are looking for as much hp and torque as possible with the smallest amount of smoke....
Old 10-19-2006, 02:34 PM
alblogg's Avatar
290k nothing but oil changes, filters and a water pump.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 11-29-2006, 12:38 AM
rrrj rrrj is offline
buy a well maintained cummins or 7.3 powerstroke. Or in other words.....................get a REAL diesel!! have 350k on my 97 7.3 and still hasnt skipped a beat. My old man made the mistake of buying a new duramax and got rid of it 2 months later cause he finally realized it was a chevy diesel? hahahahaha ABSOLUTELY LOVE CLASSIC CHEVYS THOUGH, HAVE A 77 K10 4X4 W/BB454 AND TH400. HAD A 68 Z-28 W/BB427 BUT GOT INTO TOO MUCH TROUBLE, BURNOUTS IN WALLYWORLD PARKING LOT= BAD IDEA
Old 11-29-2006, 12:51 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Now THAT'S the voice of maturity.
(sarcastic grin)
Back to the original question, my limited experience with diesels suggest possibly a leaky injector.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-29-2006, 08:48 PM
well, since you wanna get real technical, it is an Isuzu engine....and if anyone wants to buy a used chevy diesel....i would reccomend a 6.6 over the 6.5, and make sure it is an engine code 2.....not a 1
Old 11-30-2006, 08:46 AM
If you are going to get techincal.....do it right!
The 6.2 and 6.5 were designed for GM by Detroit Diesel (owned by GM at the time)...
The 6.6 was designed by a company known as DMAX which is a partnership between GM and ISUZU.....
FWIW - the injectors are not the problem...
Old 11-30-2006, 10:57 PM
This is what my old man was doing when he bought a chevy diesel
then he bought an f-350 king ranch and he was
Old 12-04-2006, 06:41 PM
EKJ EKJ is offline
Do you have a lightweigt version? Try to blend the EGR valve on the intake manifold. This often help, it is often caused by faulty Vacum valve or leaking EGR seals. Blend at valve in port to prevent engine light to come on. Best Regards Eyvind
Old 12-11-2006, 05:01 PM
Evsman Evsman is offline
Not getting enough oxygen. Check air filter, intake hoses from turbo to intake manifold. Check boost pressure. Listen for turbo spool up on acceleration.
Old 12-16-2006, 08:18 AM
69Charger 69Charger is offline
Send a message via MSN to 69Charger
Listen up weiner.. I know a thing or two about Diesels and I say that 6.5's have a problem with Injector Pumps.. I do at least 10 of them a year every year since the 6.5s started to come off warrenty. In fact.. I do more injector pumps than I do brake jobs on sunfires. And I do them because they wear out and overfuel the engine causing a severe black smoke condition...
Mark Mcknight
Elmvale Truck & 4x4
(705)-715-7867
Elmvale, Ontario
87 Mustang GT, 5.0L 5 spd, MSD ignition, BBK tubes, flowmasters, tri-ax shifter, 4.10 gears
69 Charger SE, stroked & poked 383,727 over 550rwhp
86 Chevy 2500 4x4 Plow truck, 350/TH400, 8ft fisher plow
Old 12-16-2006, 10:34 AM
Hahaha....you have no idea what you are talking about do you???
Closed Thread
