Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-16-2006, 07:13 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
running lean and rich!!
so I lost my drivers license about 9 months ago becaise I had a siezure and lost control of my 300zx. So I went out and bought a project car. i figured by the time i get my license back the car will be done.
anyways i cant really tune the car because I cant really test the car after I make an adjustment to the maf trans and the s-afc2. I got the car to idle perfect, but at idle (about 850-870 rpm) the car runs really lean. on my aem air/fuel gauge it reads about 14.5...when I rev the car it runs about the same but when i let go of the gas pedle it runs 19 then goes back to 14.5...so I made some adjustments to the maf trans and now the car runs 10.5 when under load (making boost) then goes back to 14.5 at idle.
the question. is it normal for the car to run lean at idle?
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 12-16-2006, 07:33 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Re: running lean and rich!!
not sure about lean but my car runs a little rich at idle with all my mods.
Maybe the best thing to do is have someone take it down the road with you in it to get a better tune?
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 12-16-2006, 07:43 PM
thats why i want to get it dyno tuned by a pro. I do take it up and down te street, no matter what adjustments i do to the maf trans it still the same.
1997 Eclipse GS-T
Old 12-16-2006, 08:03 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Maybe you need to make some minor adjustments to your timing.
1991 GSX 2.3 Stroker
Old 12-16-2006, 11:30 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
first off don't trust the readings unless it's a wideband
at idle, our cars should go back and forth, 14.5 being the middle. This is called the ecu's "closed loop" mode. Look that up if you want more info. Whenever we talk about running 11:1 or similar, we are talking WOT or close. After a certain amount of throttle, the ecu will kick into open loop mode, and that's when we tune. We really don't care about closed loop, that's only when the car is idling or driving around town. Basic fuel compensation will automatically deal with this. The car is cycling back and forth getting readings from the 02 sensor to get the best fuel mileage. In open mode, the 02 sensor doesn't even really read anything, the ecu is calculating what the a/f ratio SHOULD be, it has no way of knowing what it actually is. That is why narrowband 02 gauges are useless.
Let me know if you need any more clarification.
now - 2000 civic
soon - 2002 is300
Old 12-16-2006, 11:48 PM
that was a perfect. I understand now. that cleared up a lot of things. thanks. and yes, I do have a wideband.
1997 Eclipse GS-T
Old 12-16-2006, 11:57 PM
now - 2000 civic
soon - 2002 is300
