| Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here. |
![]() Join Date: Aug 2006
which ebay intake...
http://cgi.ebay.com/ebaymotors/ws/eB...5750230&rd=1,1
or http://cgi.ebay.com/ebaymotors/ws/eB...4920111&rd=1,1 there's no installed pics of the 2nd, but they both probably stick the filter in the same place?
![]() 1989 Mustang LX Coupe - ex 2.3/a4ld - 5.0/t5 conversion...with boost. 1991 Mustang LX Convertable - 5.0/AOD...stock 2001 Blazer LT 4x4 4dr 1980 BMW 320is beater |
GM S-Series Mod
![]() Join Date: Aug 2005
Re: which ebay intake...
get the first one. i got that one but the one piece version. they are all the same and all filters are a reuseable type.
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
AF Premium User
![]() Join Date: Oct 2005
i bought the same one to
2001 Chevrolet Blazer 4x4 LT Mods = TPM , Intake , Exhaust , Bearings , Polished Crank , Heavy Duty mounts , Complete rebuild done Oct '07 , HD Sun Shell . Sound = 4 12" Kicker SoloBarics L7 2000 Watt Performance Teknique Amp x3 |
Does it come with a filter?
Can someone post a picture of theirs?
'92 s-10 4x4 EC p/u '99 Blazer LT '99 Suburban LT |
AF Premium User
Yes
#6 | ||
GM S-Series Mod
#7 | |
Did it come with the K&N?
#8 | |
AF -Advisor
![]() Join Date: Sep 2003
First one.
Get the one with the chrome right up to the TB hat.
1995 Factory Blazer Service Manual for sale, PM if interested. |
#9 | ||
GM S-Series Mod
#10 | |
I have the First one to and no problems, mine came w/ a generic filter but i just put on a k&n. One thing that isnt really clear is mounting it. where the MAF gets sandwiched is kinda of tricky to mount, You may have to get creative with yours. there is a braket that usally comes with that supports it all. but its not very clear where and how
http://www.cardomain.com/ride/783126 |
#11 | ||
GM S-Series Mod
#12 | |
Advisor/Moderator
![]() Join Date: Nov 2005
With a little knowledge of physics and how an internal combustion engine operates, you'll be able to decide which cold air intake system to buy.
There are four things that need to be done to the fuel before it can burn efficiently in an internal combustion engine. First it needs to be atomized. This is accomplished when the fuel is pressurized by the fuel pump and released out of the injector/s as a fine spray or mist. Next it needs to be vaporized. This is done as the air/fuel mixture travels through the warm, (195 degree) intake manifold. The next step is to compress the air/fuel mixture, and finally, ignite it. "Cold air intake" systems, (how "cold" can that air really be without refrigerating it?) provide exactly the opposite of what an engine needs to vaporize the fuel mixture rapidly. Warm air is easier to vaporize due to the fact that it is less dense and requires less fuel to obtain a 14.7:1 A/F ratio. All engines have a cold enrichment system. It may be in the form of a choke, as with carburetors, or a computer controlled system that calculates how much fuel to provide. Back in the days of carburetors, before computer controlled fuel systems, there was a tube that was connected to a heat shield on the exhaust manifold. The tube directed warm air to the air cleaner. This tube provided warm, (less dense) air for the fuel to mix with. This helped with the vaporization process until the intake manifold warmed up sufficiently. On computer controlled, fuel injected engines, the tube is not necessary because the computer can monitor and adjust fuel mixture rapidly and efficiently. Whatever the intake air temperature is, it will be heated to about 195 degrees before it is drawn into the combustion chamber for burning. Engines run more efficiently when they "inhale" warm air, that's one of the reasons they get better fuel mileage in the Summer. With this information, you can easily make a decision on which cold air intake system to buy. Bottom line is marketing hype, it will do nothing for performance. The only advantages would be lower fuel mileage, more induction noise, a thinner wallet, and a pretty chrome tube. If that's what you're looking for, go for it. Hope this helps with your decision. |
#13 | |
GM S-Series Mod
yea the intakes don't really cool the incoming air. the engine is gonna breath the same temp air (what ever temp the outside air is) reguardless of what intake u have. if its 40 degrees out, thats the temp air the engine is getting, just the engine is breathing through a less restrictive intake assembly and thats why intakes help performance.
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain Last edited by ZL1power69; 12-01-2006 at 10:42 AM. |
#14 | |
AF -Advisor
No offense, but anyone saying performance intakes do nothing for performance need to check out the 1000s of dyno sheets online that prove them wrong.
They don't produce large amounts of horsepower , but they help.
#15 | |
AF Premium User
Anything has got to be better than the stock junk.
