whats next for my srt-4?
i got my srt-4 last december and since then i got i have put in short ram, koyo radiator, 3 inch cooler udgrade, and greddy blow off. oh i also took off resinators and i putting in 3 inch downpipe this week.
my problem is that i want the stage 2 upgrade. ive been told that i can upgrade computer without injectors or wastegate and the whole kit. does anyone know if its possible to upgrade with just a stage 2 ecu without the whole kit??? thanks |
Re: whats next for my srt-4?
Why would you want to do that though? Just keep it s0 or possibly even s1...You don't need s2 to make the power...Just do an fpr mod and mapclamp with an agp wga and call it a day...
![]() 05 Srt4 Agp 3147 w/supporting mods ![]() 97 Mx-5 T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box, |
to tell you the truth i dont the that lingo. fpr, mapclamp, apg, wge. can you be a little more specific plz. i was kinda new when i bout my srt-4.. but learned what i could for my mods that i got now...
just buy the stage2 kit. you will want all the parts anyway.
It just depends on if you are trying to be cost efficeint...
you seem to be the most knolegable person on here about the srt4's. I'm still knew to this too and could use some advice about what I should do with my car.
That all depends on where you are trying to go with it...List your goals and I can give you some suggestions, also price ranges...because I don't know about everyone else on this board but money is the enemy when it comes to my car...and boost leaks
does anyone know where I can get some HID for my SRT-4 headlights and fog lights? or should I just get the BLUBS??? is it really that big of a difference? thankx guyz...
SRT-4 **Mod'zzz** Mopar BOV NGK Iridium IX Mobil 1 Oil & Filter |
mid-as-well get bulbs....friend of mine just payed 225 for a HID kit and the bulbs prob run alot cheaper...
ThE neW wHiP:
hey, guyz...I was just wonderin'.... how many quarts of OIL...do u guyz use on ur SRT-4???
cuz I just did my oil change and I think I might of put a bit more...5 quarts!! of MOBIL 1 5w-30.... OIL JUST LOOK'S A LIL OVER full...should I drain some oil or I'm I FINE?? thankx guyz
SRT-4 **Mod'zzz** Mopar BOV NGK Iridium IX Plugs Mobil 1 Synthetic Oil & Filter Apexi Turbo Timer |
5 quarts is what you should need, of course depending on teh capacity of your oil filter and whether or not you have done some motor work
If it's not too much, and if you have a catch can, it will work it's way out of the system over time. But if neither for both, just drain a small bit out at a time until it looks good. It's always best to be a little short and add more than be a little over.
Edit> What I always do, is add 4.5qts immediately. Wait about 2 days, and add the rest(if needed).
..thankx guyz...I waz lookin' over my handbook...N I found...that they do take 5 qt. thankx...anywayz guyz...
when you install a stage 2 comp on a srt-4 it's gives you power but makes it run very poorly, my friend did it to his and now he needs new fuel injectors it overloads them and they can tspray as much fuel so it sounds like it's mis firing
