Go Back   Automotive Forums .com Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 11-27-2006, 08:19 PM   #1
EatonZ
Valve Cover gasket
I'm going to be replacing the gasket soon and wanted to know if any of you have done this. Is there any thing "special" that I should do, or is it pretty straight forward?
EatonZ is offline   Reply With Quote
Old 11-29-2006, 02:38 PM   #2
Doug Tatham
Re: Valve Cover gasket
You will need some blue gasket sealant. On the front side of the gasket there is a place where you switch from the gasket to what looks like a half o-ring. You have to place a bit of sealant on both sides where the materials meet. I advise getting a magnet retriever (not sure of correct name). It looks like a telescoping pen with a magnet on the end. The bolts on the back side of the cover are a bit difficult to reinstall and easy to drop and lose. I put the bolt on the magnet then use the retriever to place the bolt in position, then turn it a couple turns to get the bolt started. I have fairly large hands, you may not have the same problem. If you lose a bolt, remember that they're metric.
Doug Tatham is offline   Reply With Quote
Old 11-29-2006, 11:39 PM   #3
EatonZ
alright, thanks for the info Doug.
